Mark V Field has 25 watt output.
Discussion in 'General Technical Questions and Answers' started by N9EA, Apr 17, 2021.
  1. N9EA
    N9EA XML Subscriber QRZ Page
    Good day all,
    Before I send this in (probably yet another topic as to where), I'm wondering if I'm missing something on power output. Any increase in the RF power knob past 10:00 (about 25w) is useless. The Class A button is NOT depressed and my antennas are resonate. I'm new to this rig and am a second owner. Receive is fine but when nobody is returning my calls in any pileup I started looking at power output. Please tell me it's something stupid, I can accept that.
    Thanks,
    Mark N9EA
  2. CX3CP
    CX3CP Ham Member QRZ Page
    HI, are you talking about an FT1000 ?, first at all, check the RF Pwr knob FCCW and the MIc Gain FCCW , after that do a factory reset, if that do not correct the power output., then maybe you are in trouble with the Mark V.
    Check CW
    Good luck
    [29(0)] + POWER on: Resets all menu setting to factory-default.
    [SUB(CE)] + [ENT] + POWER on: Resets all memories (except menu setting) to factory-default.
    [SUB(CE)] + [29(0)] + [ENT] + POWER on: CPU master reset for all memories and menu setting.
  3. N9EA
    No joy but thank you
  4. W4NNF
    W4NNF XML Subscriber QRZ Page
    What mode are you in and how are you measuring the power?
  5. WB2WIK
    Have you checked the power supply?
  6. N9EA
    CW, using the onboard power meter (all I have)
  7. N9EA
    Using it's AC power on a dedicated circuit, voltage fine. Looking for the DC cord now.
  8. W4NNF
    Into a dummy load? If you have a dummy load use that instead of the antenna.
  9. N9EA
    No difference. Wish I could find that DC cord...
  10. WB2WIK
    Yeah, that "might" reveal something, in case the internal power supply has a problem.
    I never owned the Field (I did own an FT-1000MP MK V for a while, but that used a separate, dedicated power supply and I think it was 28Vdc, not 12V) so I don't remember if its meter can display the power supply voltage. If it can, switch to that and see what it reads when you transmit.
ad: AbAuRe-1
