Magnetic loop antenna on the Alps: experiences and issues
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by IU2GLX, May 30, 2017.
  1. AK5B
    AK5B Ham Member QRZ Page
    Yep.
    KE0EYJ likes this.
  2. AF7ON
    AF7ON Ham Member QRZ Page
    I have an MFJ 1786 and have operated it over the temperature range here in southern Arizona (-5 C to 45 C) with no problems. We mostly have very low humidity and condensation is not usually an issue. There is little to go wrong mechanically with a gear motor turning the tuning capacitor and gear motors should be OK over most temperature ranges. However, condensation and ice are two known potential problems with gear motors.
    Vertical mounting is generally preferable, but not lower than about one tenth wavelength to minimize ground losses. I have a rotator but rarely use it as it points in the most favored direction of DX signals. The null on low-angle signals can be an S point or more, though. At high angles, it is pretty omni-directional.
    Mike
  3. SGO1
    SGO1 QRZ Member
    Well OH8STN has been operating STL's from about 2 years now in Finland around the 65° paralel without any issues. The weather is probably similar to what you'll experience in the Alps.
