MAGNETIC LOOP 10-40M DIY
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by 4X1WD, Aug 16, 2021.
  1. 4X1WD
    4X1WD Ham Member QRZ Page
    Hi,
    this is my magnetic loop,
    in this page, you can find the pictures,
    the stl files for 3d printer, the diagram of the controller and the program,
    M0HWD
    K2CAJ, W7JMP, KK4NSF and 1 other person like this.
  2. 4X1WD
  3. AF7ON
    AF7ON Ham Member QRZ Page
    Wow - that is an impressive home-brew antenna!
    I wonder if you have found any interaction with the balcony rail and whether you've considered raising your antenna a bit higher? (A height a tenth of a wavelength or more above earth reportedly reduced ground losses).
    Mike
  4. 4X1WD
    Hi Mike,
    thank you for your reply,
    sorry for the late reply,
    i raised it and then it fall with the wind.........
    but as it is now i am surprised of the results
    i am using 100w and never have any problem getting out 10-40 m
    only if its tune exactly....
    best Daniel M0HWD
ad: w5yi
