ad: vanity
Mag mount inside truck bed?
Discussion in 'On the Road' started by N0APE, Nov 11, 2019.
  1. N0APE
    N0APE Ham Member QRZ Page
    How much will it degrade my antenna performance by using a mag mount in the middle of the bed?
    I can't do a traditional NMO mount for a few reasons, mainly height/clearance problems.
    Curious how much it's going to hurt performance with a decent amount of the antenna below the bed rails.
  2. AC0GV
    AC0GV Ham Member QRZ Page
    A lot but worry first about SWR and radio damage. The longer the antenna the better it will work, keep the SWR low and you should be OK, just reduced coverage and the cab will block forward signal most.I hope it's not a new f150 or other aluminum truck.
  3. N0TZU
    I think you would be much better off with a 19" ground plane on the bed rail. Or an antenna on the front cowl. I had similar problems when my truck carried a camper which overhung the cab. I put my antenna on the cowl with a mount coming up from the hood seam. It worked quite well.
  4. AI7PM
    AI7PM Ham Member QRZ Page
    Don't even bother.
    Cowl mount a Laersen 2/70. It may or may not slightly touch a garage door going in and out. It's probably the best compromise to a roof mounted antenna.
    N0TZU likes this.
  5. N0TZU
    Oops, just realized that I said cowl above when I meant fender. The antenna was mounted at the seam between the hood and fender.
    AI7PM likes this.
  6. AC0GV
    Like this, not perfect but many in my area use them.
    N0TZU likes this.
  7. N0APE
    Think I'm going to fab up an elevated mount that goes into the bed. Thinking a cross bar above the wheel wells.
  8. N0APE
    Got the antenna dialed in today. Ended up putting it on the drivers side wheel well hump. Swr checks out fine, below 1.5 across both bands edge to edge.
    Made contact with one of the further away repeaters that was located on the opposite corner of the truck if that makes sense, truck was aimed south and the repeater is ssw from where I was parked about 35 miles away with 5 watts.
    N0TZU likes this.
  9. AI7PM
    What kind of antenna did you settle on?
  10. N0APE
    Just a cheap Tram dual band nmo on a 5.5” mag mount.
ad: AlphaRF-1
