Maclogger+WSJT+JT Bridge = Icom 7300 rig control
Discussion in 'OS: Mac OS' started by HI8SMX, May 17, 2018.
ad: OK1UUad-1
  1. HI8SMX
    HI8SMX Platinum Subscriber Platinum Subscriber QRZ Page
    I am using MacLogger, WSJT and JT Bridge (all new versions) on a 2013 MacBook Pro and all of them are working just fine separately. But if I want to control my Icom 7300 with WSJT I need to disconnected from Maclogger and viceversa.
    I've read that one can use JT Bridge to allow both programs (Maclogger and WSJT) to operate the radio at the same time, but I haven't been able to make it work, regardless of following up on instructions.
    Any advices? recommendations?
    thanks,
    Santiago
    HI8SMX
  2. K3DCW
    Two program can't control the same port at the same time in macOS. In this setup, you need to give MacLoggerDX full control of the port, setup JTBridge as per the instructions, and set WSJT-X to use the "DXCommander" rig control (again, as per the JTBridge instructions). JTBridge will serve as a "bridge" between MLDX and WSJT-X. Full instructions are available here:
    https://jt-bridge.eller.nu/documentation/
  3. HI8SMX
    Thanks K3DCW. That is what I've been trying to achieve and it's not working. I'm following the instructions in Jt Bridge documentation and keep getting the "Dx Commander sent a bad mode USB-B" error. Will keep reading and trying.
    73's
  4. K9JRI
    K9JRI Ham Member QRZ Page
    I had a similar problem with my K3s installation. Try going to the JT-Bridge preferences, General Tab and in the "Station" fields enter USB-B in the mode to use for Data/PKT. If that field does not match what Commander returns you will get the error.
    very 73 - Mike - K9JRI
    K3DCW likes this.
  5. HI8SMX
    Thanks Mike. Problem solved!!
    73's
    Santiago, HI8SMX
    K9JRI and K3DCW like this.
  6. NC0L
    NC0L XML Subscriber QRZ Page
    Thanks, this helped me out!
    73 - Bob, NC0L
    K3DCW likes this.
  7. K3DCW
    I'm glad it helped, but that is also a bit out-of-date.
    MLDX can now interact with WSJT-X directly. See https://dogparksoftware.com/MacLoggerDX Help/mldxfc_wsjtx.html
    There are still some advantages to using JTBridge, however. So if you like the setup, there's no reason to change.
