LSB or USB?
Discussion in 'Working Different Modes' started by AG6HO, Jan 3, 2011.
  1. AG6HO
    AG6HO Ham Member QRZ Page
    I recently updated my equipment to give me access to 40M and 80m. I cannot remeber to rule for using LSB vs USB. Can someone help?
  2. AC0FP
    AC0FP Ham Member QRZ Page
    Use LSB on 40 meters and other lower frequencies. The higher frequencies, 20 meters and above, use USB.
    fp :)
  3. K9STH
    K9STH Ham Member QRZ Page
    LSB on 160, 75, and 40 meters. USB on all higher frequency bands.
    There are some groups on the LSB bands that are using surplus military equipment that has USB only. But, those are very specialized groups. Nothing illegal about using the opposite sideband, but convention is as stated.
    You definitely have to consider the bandwidth of your signal and keep far enough away from the band edges to keep your transmitted signal within the band. That generally means to keep around 3 kHz above the lower segment frequency when running LSB and around 3 kHz below the upper segment frequency when running USB. This is on the indicated frequency on the dial. There are transmitters than do have less bandwidth and that can operate a little less from the band edges. But, keeping around 3 kHz away gives a little bit of safety from going outside of the band.
  4. KD0CAC
    KD0CAC Ham Member QRZ Page
    Channelized 60m is recommenced USB also .
  5. AB1OD
    AB1OD Guest
    I think the word you're looking for is "mandated".
    60m = only 5 channels, only USB, only phone, and only power equivalent to 50w dipole.
  6. KD0CAC
    60m is mandated on specific frequencies making it channelized , but like the rest of the ham bands , the mode is convention not mandated I was thinking .
    It could be that because of 60m being on specific frequencies , that only 60m the mode is mandated , that I am not sure of , but does make sense .
  7. AG6HO
    thanks for the info. Time to dust out the rusty info. 73
  8. W7CDX
    W7CDX Ham Member QRZ Page
    From Extra Class Question Pool:
    E1A08
    What is the only emission type permitted to be transmitted on the 60 meter band by an amateur station?
    Correct Answer:
    Single sideband, upper sideband only [97.303]
  9. W5RKL
    W5RKL Ham Member QRZ Page
    USB suppressed carrier is the ONLY authorized mode for 60 meters. The authorized frequencies for 60 meters are 5330.5Khz, 5346.5Khz, 5366.5Khz, 5371.5Khz, 5403.5Khz with a maximum authorized band width of 2.8Khz, centered around each 60 meter frequency. The maximum authorized power output on 60 meter is 50 watt PEP.
    73s
    Mike
  10. WB2WIK
    It's actually 50 watts ERP.:)
    50W PEP wouldn't be so bad, but the ERP limit is really restrictive.
