ad: M2Ant-1
LoTW to Ham Radio Deluxe Problem...
Discussion in 'Ham Radio Deluxe - HRD' started by KB1ZQ, Jan 23, 2021.
  1. KB1ZQ
    KB1ZQ XML Subscriber QRZ Page
    I am using HRD to control my IC-746 and Log using WSJT-X and JT Alert. Working contacts and all work as they should. In HRD Log my mode is set to FT4. However I just started working FT4 and have uploaded several log entries to LoTW, they process fine.
    When I Download the confirmations from LoTW, the file fails to load. I open the ADIF file and see the "Mode" as MFSK with a sub mode of FT4.
    Am I missing something here... I cannot get confirmations for FT4 to populate in the log...
    Comments please...
    Thanks
  2. K2IE
    K2IE XML Subscriber QRZ Page
    There is a whole video produced by WA9PIE (one of the owners of HRD) on this very subject. The bottom line is that under the ADIF standard, FT4 is a submode of MFSK.
  3. KB1ZQ
    Thanks, exactly what I was looking for... Used to Paper manuals (PDF)... Got nothing on a search... 73 Hal
  4. KB9HGI
    KB9HGI XML Subscriber QRZ Page
    I did what you said in the video made modes default then went in and added submode. Now in my log it does says Mode MFSK and submode FT4 and I uploaded the FT4 contacts to LOTW again but still shows data. When I go into QRZ log and import from LOTW it shows them logged twice it shows FT4 from HRD log and Data from the LOTW import. It does not do this with FT8 LOTW will confirm it as FT8 when I import to confirm contacts. Any other idea?
  5. KB9HGI
    In my HRD log it says LOTW Sent yes and for LOTW RX it says no for all FT4 contacts
  6. WA4MIT
    WA4MIT XML Subscriber QRZ Page
    Hi KB9HGI what version of HRD are you using?
    73 Morris WA4MIT
  7. WA9PIE
    WA9PIE QRZ Lifetime Member #305 Platinum Subscriber Life Member QRZ Page
    For the LOTW to match, BOTH parties need to upload FT4 QSOs with "MODE=MFSK" and "SUBMODE=FT4" (and I'm sorry, it wasn't my idea to make FT4 a submode under MFSK; we're just conforming to the standard here).
    I've seen cases where one party uploaded as MODE=FT4 and the other party has MODE=MFSK and SUBMODE=FT4... and the person who uploaded MODE=FT4 has to upload them again in order to get a match.
    Mike, WA9PIE, VK4EIE
  8. WA9PIE
    And you can see some of this in a video on the HRD Software YouTube channel.
  9. NB3R
    NB3R Premium Subscriber QRZ Page
    There was a time when HRD did not meet the ADIF standard for FT4. If you uploaded them before the fix they will be wrong in LoTW.
  10. WA9PIE
    Yeah, that was 2 years ago though. We haven't seen much of this since then.
ad: M2Ant-1
