LotW problem in Windows 2000
Discussion in 'Logbooks & Logging Programs' started by W3GER, Apr 11, 2006.
  1. W3GER
    W3GER Ham Member QRZ Page
    Thanks. I ran the gamut with the ARRL LotW support people. Their final statement: "It must be a Win2K problem and we can't help you".
    73 de W3GERry
  2. W3GER
    Thanks for your help. The user I log in as IS in the Administrators group.
    73 de W3GERry
  3. W3GER
    Apparently "Permission denied" is not a sufficiently serious error to make it in to any event logs.
    But thanks for the try!!
    73 de W3GERry
  4. VA2FCS
    VA2FCS Ham Member QRZ Page
    Did you check if there is an updated version of the TQSLCERT.EXE program ?
    Does the TQSLCERT.EXE program creates a log file ? maybe you would find useful information in it.
    Did you make any modifications in Windows 2000 after installing it and before installing your certificate ?
    Sylvain
  5. W3GER
    --I first experienced the problem under 1.10. I DL'd the latest (1.11) and have same problem.
    --Apparently no log file.
    --Only "modification" was to update to Service Pack 4.
    Thanks anyway!!
    73 de W3GERry
  6. VA2FCS
    Maybe you could try to uninstall SP4, install the certificate and reinstall SP4 ?
    Sylvain
  7. WA7KKP
    WA7KKP Ham Member QRZ Page
    May I suggest Linux -- Windows has too many issues that haven't been properly addressed -- network security and the rampant virii on the Internet being the glaring example.
    Gary WA7KKP
