LoTW Download Issue - ALL such threads merged to this one
Discussion in 'Logbook User Forum' started by N2DZ, Mar 9, 2020.
Tags:
ad: OK1UUad-1
  1. N2DZ
    N2DZ XML Subscriber QRZ Page
    Update: it went through and said 14 new qso's with 2 confirmations but log does not show them. I will look into it.
  2. W7TCT
    W7TCT Premium Subscriber QRZ Page
    it is very, very slow... takes awhile to load. It is current for me from what I uploaded last night.
  3. N2DZ
    Thanks. Yeah I think something is going on with lotw because I tried to download from there to qrz and it is not going through and I tried to upload to lotw from HRD and I get
    Error: LOTW rejection, upload successful
    and then nothing.
  4. K8HIT
    K8HIT Premium Subscriber QRZ Page
    I had trouble yesterday with uploads.
  5. N2DZ
    LOTW side?
  6. VE3CGA
    cant even get lotws site up on the web.
    log transfers have been slow since the dx contest
    even tqsl is very slow
  7. N2DZ
    Yeah I totally forgot about it being the Monday after a weekend contest.
    KP4SX likes this.
  8. K8HIT
    I just downloaded matches from this past weekend without a problem.
  9. CO2BK
    CO2BK XML Subscriber QRZ Page
    Si algun colega me pudiera explicar cómo descargar mi log completo del QRZ y cómo se podría hacer para importar el log del QRZ hacia el log del LoTW. Es que tengo confirmaciones en el QRZ que no aparecen registradas en el LoTW y por tanto, tampoco sirven para los premios que se otorgan en el LoTW. Por favor, si ouedeb responderme a mi correo:
    luis1955@nauta.cu
  10. W1DQ
    You must first set up LoTW Access as follows:
    Open your logbook
    Click on SETTINGS
    Find LoTW Access and click on SETUP
    Follow instructions at HELP https://s3.amazonaws.com/files.qrz.com/static/qrz/lotw_cert_guide.pdf
    Once you have enabled LoTW Access, then:
    Open your logbook
    Click on SETTINGS
    Scroll down and select from choices: "Download from LoTW" or "Export and Send to LoTW"
    Primero debe configurar LoTW Access de la siguiente manera:
    Abre tu cuaderno de bitácora
    Haga clic en AJUSTESEncuentra LoTW Access y haz clic en SETUP
    Siga las instrucciones en AYUDA https://s3.amazonaws.com/files.qrz.com/static/qrz/lotw_cert_guide.pdf
    Una vez que haya habilitado el acceso LoTW, entonces:
    Desplácese hacia abajo y seleccione entre las opciones: "Descargar desde LoTW" o "Exportar y enviar a LoTW"
