Loop Antenna
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by K1AKI, Mar 17, 2010.
  1. W5RB
    W5RB Guest
    Response from the support e-mail address is sometimes unfortunately slow . Call them , and I'm confident you'll get a prompt resolution of your problem .
  2. W8NSI
    W8NSI Ham Member QRZ Page
    MFJ Service
    When I bought my super tuner from MFJ, I had an issue with the counter. They responded quickly and even sent a new counter for it, no charge. I guess results vary...
  3. K8JD
    K8JD Ham Member QRZ Page
    My Loop
    Glad you found the problem and hope you can get the tuning box to work.
    I have plenty of room for a fullwave wire loop in the woods behind my house.
    Nothing fancy, just used (Length in feet=1005/F in mHz) as a starting point. Suspended between 4 convienient trees at 35 ft up and fed with a quarterwave of 75 ohm RG6 spliced to a long run of RG8x to the house. !
    No tuner needed for this scheme.
    Beats a dipole by a few S units up to around 1000 miles and farther than that I use my vertical Butternut antenna.
    I have a 2nd loop up for 30M.
    I tried one for 80M but there was no way I could get up high enough to get it to work properly, needed to be about 40 feet HIGHER:eek:, so it worked about same as my dipole so I took it down.
    Good luck, JD
  4. W7LPN
    W7LPN Ham Member QRZ Page
    The link didn't post before...?
    http://www.n4kc.com/ see skywire :D
