looking for an inexpensive SWR meter
Discussion in 'Amateur Radio Equipment Reviews' started by KK4SUH, Jul 31, 2013.
ad: QSOToday-1
  1. K8ERV
    K8ERV QRZ Member QRZ Page
    Or the meter is reading correctly and the antenna is off tune.
    Check it with a known good dummy load.
    TOM K8ERV Montrose Colo
  2. KK4SUH
    KK4SUH Ham Member QRZ Page
    The particular seller I purchased the J-pole from checks all antennas with his antenna analyzer, but it still wouldn't be bad idea to grab a dummy load, do you know of any inexpensive ones that work well?
  3. K8ERV
    The J-pole could pick up some SWR depending on how you connect to it and how/where you mount it.
    If you have or can borrow 100' or more of RG-174, that small coax is so lossy at 2M very little energy gets reflected
    back to the source. Even if not terminated, tho a 50 ohm resistor helps.
    I picked up a Shack finned resistor 21-506 at a yard sale. It is Very good, even at 440. Don't know if it is still
    available or at what cost.
  4. KB8TVN
    KB8TVN Ham Member QRZ Page
    I have a old Knight P-2 which seems to match the readings of my Daiwa cross needle 2 meter, I like the fact that it has a remote sensor. But I'm only putting 10 watts into it and must keep the sesitivity down around "2" or it will instantly peg the meter. I have another with a bad meter which I might try to use with an Arduino.
ad: M2Ant-1
