For Sale Lnr ld-11 and buddipole delux
Discussion in 'Ham Radio Gear For Sale' started by W5ABH, Apr 5, 2018.
  1. W5ABH
    W5ABH Ham Member QRZ Page
    I have for sale a fantastic qrp hf+6 meters all mode portable transceiver.
    This is an awesome radio. The filtering in it is superb and a pleasure to listen to.
    Here is he info from their website....
    The new LD-11is Digital Direct Conversion, SDR type, build-in CPU (SM32a) DSP radio in which RF signals are directly converted to a digital data via differential and balanced A/D converters. This enables direct sampling with extremely low phase and floor noise.
    The DSP is unique and features two independent channels. It also employs a unique differential algorithm within the software which is applied for IQ processing of the channels with phase suppression of the unwanted side-band channel.
    The balanced ADC and DAC gives additional noise floor reduction and the receiver can handle interfering signals that are 100 dB stronger than the desired signal at a frequency separation of 10 kHz, and is about 130 dB stronger at 50 kHz separation. As the receiver and transmitter are using the same DSP channel, there is no gap between the receiver performance and the transmitter performance. Thus, there is a clean neighborhood on the bands. At the development stage, our intentions were motivated by the TX side-band noise of existing SDR manufacturers, so our aim was to fully equalize our transmitter to have noise performance that is compatible with the best modern receivers, or even better. After a arduous year of development , we think we achieved it!
    This 11+ band radio is based on the LD-5, which has proven to be one of the most exciting QRP transceivers introduced in the last few years. Quite frankly, the performance rivals high end units offered by other manufactures at a much lower price point. Our motto is that we make QRP transceivers that you will want to take out in the field (without fear of breaking the bank).
    Transmitter
    Input Power: 11.5-14.8 VDC
    Output Power: 5 – 8W
    Measurement: SWR and Power:Numbers or Bar indicators on display
    Supply Voltage:Real voltage on display
    Two Modes CW: Select Straight Key or Paddle (built-in Iambic)
    Receiver
    Receive sensitivity: 0.15uV w/o preamp
    Ant Preamp: +16 dB
    Spurious Response Rejection: IMD3 -48Db/ 5W
    IMD5 -43dB
    ATT: -12db
    Specifications:
    Frequency Range: 1800 kHz – 29.990 MHz HF +50-54MHz
    160, 80, 60, 40, 30, 20, 17 and 15, 12, (11), 10, & 6 meter all mode operation
    Modes: USB, LSB, CW, CW-R, DIGITAL DATA:CAT –USB jack : CW, PSK, RTTY, SSTV – 3.5mm jack
    AM/FM as well.
    PAN mode: Easy to Find quiet point +/- 24kHz from main frequency.
    Power: 5W output in CW / SSB
    Frequency Stability: +/- 3 ppm (Si570 defined) typical over 0-50 deg C
    Supply Voltage: 10.5V min to 15V max 350mA receive and 1.5 to 2A typical in transmit
    LO temp. Stability: +/- 2.5
    Antenna: 50 ohms BNC
    Dual VFO
    Memory: 100 memory storage per band Memorize frequency, mode, VFO’s
    Built-in speaker: 8 ohms, .5 watts
    Dimensions: 4.724”L X 3.937”W x 1.957“H
    Weight: 19oz/0.54k/excl. mic.
    Iambic key: Mode A and Mode B
    Pitch CW: Controls CW offset. The sidetone pitch is automatically set to equal the offset
    Notch Filter: Automatic Heterodyne filter for SSB from -6 to -40 db
    Noise reduction: Level of attenuation of the noise from 1 to 50- use minimal necessary
    Noise Blanker: Adjusted in the range from value 4 to 12 readings depending on interference
    CW VOX: Break in delay in CW – adjustable from 0.1 seconds to 5 seconds
    CW memory keyer Choose Iambic Mode A or B
    VOICE VOX VOX Delay adjustable from 0.1 seconds to 5 seconds
    SSB VOX Level: VOX GAIN 10-100 10 IS MOST SENSITIVE
    SSB EQ 3 band Bass, treble, middle audio boost on transmit - up to environment and voice
    8 Different filters (incl): 4 of 4 for CW/ SSB - 1-3 factory presets – No.4 adjustable for CW/50-1000Hz/ and SSB/250-3.6KHz
    The HOTTEST new QRP Multimode HF+6M transceiver on the market.
    160M to 6M coverage!
    AM/FM modes!
    BUILT-IN Band Scope Features
    I am asking 900 shipped for the radio, including the hard foam lined case in the photos.
    Also included in this package deal is the dcp paddles by American Morse, the stock microphone, and power cord.
    As well as the buddipole deluxe kit with extra telescoping whips, the mast and all which is nearly new. I’ve used it maybe 3 times. The photos aren’t great but I had a hard time uploading photos from my phone, the file size was too large??
    Contact me on my email on my page. I accept paypal and shipping is included in the 900$$ asking price to the lower 48 states. Thanks for looking.
  2. W5ABH
    Sorry No trades and would rather sell all the equipment together at this point. Thanks for the inquiries.
  3. KM6JMR
    KM6JMR Ham Member QRZ Page
    Is it still available? If so send me your paypsl acct email
    W5ABH likes this.
  4. W5ABH
    Yes it is still available. I’m sorry I have checked in here in a while, my email listed on my page is the best place to reach me. If you are still interested km6jmr email me at w5abh73@gmail
  5. W5ABH
    The buddipole has been sold the lnr is still available-$615 shipped
  6. QRZ
    Important Rules
    Have you read our Swapmeet Safety Rules?
    This forum enforces a set of buying/selling safety rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Our moderators review every post in this forum and will flag or delete those that do not conform.
