ad: hrd-2
Linksys WRT54G Firmware Upgrade
Discussion in 'Computers, Hardware, and Operating Systems' started by N4CYA, Apr 19, 2007.
  1. N4CYA
    N4CYA QRZ MODERATOR Volunteer Moderator QRZ Page
    Guys & Ladies,
    I'm trying to update my Linksys router WRT54G with the new version 8 that just came out awhile ago hadn't had the chance to update as of yet. The firmware file is a .bin file what program do I need to use for it?
  2. WD8OQX
    WD8OQX Ham Member QRZ Page
    Most of the ones I've seen, you run the install from within the router itself.
    I use my web access to my router & there is a menu item that lets me do it.
  3. KE7IPY
    KE7IPY QRZ Member
    OQX is right on with that. You just open the admin console and use the "Firmware Upgrade" function. When it asks for a file, point it at the .Bin.
    I've tried most all of the firmwares for WRT54G and by far the best one I've found is Tomato. It's nice to look at and is well organized.
  4. K5GHS
    K5GHS Ham Member QRZ Page
    Yep, its in the admin part.
    Make sure you do it from a wired computer-they can flake on wireless sometimes.
  5. PA5COR
    PA5COR Ham Member QRZ Page
    As described above.
    I'm using the GL type and Tibor software wich allowes an lot more settings of wich one is to set the output to 250 mWatts.
    Homebrew antenna on the roof makes acces possible for an 3 mile radius.
    Cor
