Links on my callsign page
Discussion in 'Community Help Center' started by EI2GLB, Oct 4, 2010.
  1. M0LEP
    M0LEP Ham Member QRZ Page
    Basically, something in the editor code is still broken. Allegedly the bug is being worked on. Best option for now is to leave off the editing and wait a while until the editor bug is fixed. Hopefully it won't be too long, but I'm not holding my breath... :rolleyes::(
  2. K2DSL
    K2DSL Platinum Subscriber Platinum Subscriber QRZ Page
    It looks to me, at least on my bio page, that things are back to normal. Links on my page that were to other sites are correct and no longer pre-pended with www.qrz.com . I looked on your page at http://www.qrz.com/db/M6LEP and I still see qrz.com pre-pended so maybe the issue requires some more time. Another option would be to see if re-editing your bio page causes it to correct itself.
  3. M0LEP
    Last time I tried, about an hour and a half ago, the links were re-mangled. This time, fingers crossed, the corrections seem to have stuck...
  4. EI2GLB
    EI2GLB Guest
    just tried it and still not working for me
  5. A65BR
    A65BR Ham Member QRZ Page
    The same problem here.
    I have 2 links only - flagcounter and logsearch. Both are "modified" with "qrz.com/db".
    The same links on another user's pages are working well.
    What's wrong?:confused:
  6. LA0EM
    LA0EM Ham Member QRZ Page
    Links not working
    After 2 days of puzzling it appears my link is now working again.
    At dawn i tried to remove the ED but it just jumped in again on save.
    Then i removed the link totally,clicked Save, then opened the editor and added the URL again with the tag * target="_blank" *.
    Its now working again,
    Dont know if *target="_blank" * had anything to do with it but i just pass it on anyway.
    73.s John
    :D
  7. UA6JD
    UA6JD Moderator Volunteer DX Helper Platinum Subscriber QRZ Page
    target="_blank" - is mean that your link is open in new window. It not do anything with web page.
    Problem is fix yesterday and I am playnig in HTML window without any trouble.
  8. UA6JD
    Олег -
    зайдите в режим корректировки HTML и там увидите строку вашего счетчика с искажением :
    http://www.qrz.com/ed/http:/s04.fla...8/maxflags=125/viewers=0/labels=1/pageviews=1
    надо строки http://www.qrz.com/ed/ удалить и добавить одну косую линию (как обычно после http)
    У вас должно быть
    http://s04.flagcounter.com/count/PU...8/maxflags=125/viewers=0/labels=1/pageviews=1
    не совсем коректно сгенерирован HTML код вашего счетчика, но это уже на любителя.
    После двухдневного бага с гиперссылками сегодня уже восстановил очень много страниц.
    Если будут проблемы - пишите - все проблемы и пожелания решаемы.
  9. EI2GLB
    EI2GLB Guest
    Seems to be working now
    Thanks
    Trevor
    EI2GLB
  10. A65BR
    Spasibo!
    A slona to ja i ne uvidel... (c) V smysle chto tolxko odna kosaja ostaetsja posle http... hi-hi.
    73!
