Lightning - sferics detectors
Discussion in 'Homebrew and Kit Projects' started by N8YX, Aug 6, 2008.
  1. N8YX
    N8YX Ham Member QRZ Page
  2. N0WVA
    N0WVA Ham Member QRZ Page
    You know, this would be a good first project for someone getting started in homebrewing.
  3. AB8RO
    AB8RO Ham Member QRZ Page
    You can get everything at radio shack except for the inductors. Any ideas on an easy way to construct 10mH inductors from commonly available materials? Ideally, that would not involve toroids because they aren't always easy to find.
  4. N0WVA
    Hmmm, thats a lot of windings, toroid or not. Then you have to come up with the small wire,too. First thought says get one from Mouser, but then that doesnt hold to the "all RS" parts.
    Then again, do they still carry meters?
    Is there a way to make a low-pass filter at this low frequency from RC combinations? And what frequency should be the cut-off? Well below the BCB I suppose.
  5. KB9BVN
    KB9BVN Ham Member QRZ Page
    Neat project. Mouser has the 10mH and 1mH inductors. About $4 each though....plus shipping...egads.
  6. AB8RO
    My thoughts exactly. Surely there's a better way than that? What types of cores could one use to make it practical? There was an interesting discussion about a similar issue on one of the Indian ham web sites where they used, I believe, brass, don't quote me on it, cores to avoid the high cost and low availability of toroid cores.
  7. AB1GA
    AB1GA Ham Member QRZ Page
    Well, if I had to scrounge something I'd first get the antenna core from an old AM radio, which should work at the frequencies lightining detectors use.
    Then you'd need some wire. Since it's a receiver, size isn't important, so just about anything would do, like the winding from an old transformer from a wall wart. As you wrap the coil, put a sheet of paper between layers so you that if the insulation is bad in a couple of spots you just short out a turn instead of a whole layer.
  8. AB8RO
    I have about a half dozen AM loop antennas and they are all in the 500 microhenry range. Of course you could change the cap to compensate. Perhaps someone would like to comment on what effects the shift away from a high L to C ratio would have?
  9. AB1GA
    More Wire!
    Or another junk coil. How about a deflection coil from a dead TV?
  10. AB8RO
    That's the right idea, what can be pulled. Here's something that I think will work. I pulled this choke from the AC input of a computer power supply. It's a dual choke, but I don't know if you could use both halves or you would need two of them. It seems that there must be some coupling.
    At any rate, it's about 8 mh. Close enough to make it work.
