ad: FlagAnt-1
Ldg z100 plus and yaesu 857d not working
Discussion in 'Ham Radio Discussions' started by M6OTU, Aug 10, 2018.
  1. N7AHE
    N7AHE XML Subscriber QRZ Page
    For the YT100 menu 20 must be set to CAT. Not sure about the Z100.
  2. M6OTU
    M6OTU Ham Member QRZ Page
    Yes the yt is cat controlled. Where the z100 plus connects via the acc jack
    N7AHE likes this.
  3. W5TTP
    W5TTP Ham Member QRZ Page
    Also, the atas antennas do not require an additional tuner (like the ldg). If we are unable to answer your question on this site, I will unbox my 857 and power it up in the truck to verify settings.
    If your settings are correct on the 857d, a chat with ldg may be in order.
  4. M6OTU
    Everything appears to be correct settings wise. I've checked then checked again done a radio reset then checked again. I mailed ldg earlier and got the basic " never heard of this before" reply. Telling me to send it to the vendor. But.... The tuner works on other radios perfectly fine. And the radio works other tuners fine ( scratching head ) .
    It's as if the 857 is transmitting that is confusing the z100 plus and I can't put finger on it.
    Cheers for all the suggestions they are all very welcome and proving I am not going insane.
    Regards
    Rob
  5. 2E0WMG
    2E0WMG Ham Member QRZ Page
    I was thinking along those lines with menu 85 but you beat me to it..
    I have used an 857 and other Yaesu radios along with the Z100 (precursor to the z100 plus) for 14 years and have never had this problem.
    He could try a full microprossor reset, page 117 of the manual..
  6. M6OTU
    Tried the atas settings guys. No difference. Also full reset on the radio to no avail.
    Cheers
  7. K3BOA
    K3BOA XML Subscriber QRZ Page
    I use an FT-857 with an AT1000 ProII while in the shack or a Z-11 ProII while portable, Y-ACC cable with menu settings: #85 off, #20 CAT.
  8. M6OTU
    Yup tried those settings. Going round in circles so seen as the tuner works on other radio's the radio is going back on Monday morning as there is obviously a fault with it. Can't even use the tuner manually without the y-acc cable.
    Cheers for the input
  9. W5TTW
    W5TTW Platinum Subscriber Platinum Subscriber QRZ Page
    Sorry if I missed it, but does your 857 work with any other tuner?
