KPC3 stand alone config for APRS
Discussion in 'General Technical Questions and Answers' started by KA0ZIS, Aug 20, 2008.
  1. KA0ZIS
    KA0ZIS Ham Member QRZ Page
    Can anyone tell me how to configure the KPC3 for stand alone (home base, not mobile) use for APRS?
  2. N5KRC
    N5KRC Ham Member QRZ Page
  3. AC1U
    AC1U Guest
    Try these settings. They worked for me after changing the obvious callsign, mynode, and the appropriate other location specific settings.
    Initialization file for configuring KCP3+ as an APRS digipeater
    Find and replace "callsign" throughout this file with the desired callsign.
    Edit the LT1 through LT4 lines to include the coordinates and PHG of the digipeater
    along with any beacon message string desired.
    Edit the LTP1 through LTP4 lines to reflect the desired paths to be used for
    beacons at the time intervals defined in BLT1 through BLT4.
    After editing, delete this commented section and save the file under a new name.
    Use a terminal program such as Procomm or Windows HyperTerminal to connect with
    the KPC3+ Verify you can get a CMD: prompt, type commands into the KPC3 and see
    responses. Then do a text file upload to read this file into the KPC3+ Set the
    terminal program to add a delay of 100-200mS between lines to give the KPC3 time
    to process each line.
    Note that this listing is a DISPLAY dump from an already-configured KPC3+. The TNC will choke on this listing if you just try to
    edit and upload this list. This version has been edited for the correct command for SETTING, not just Displaying the settings.
    The user of this list is solely responsible for the settings so verify any changes are correct for your use.
    8BITCONV ON
    AUTOLF ON
    AX25L2V2 ON
    AXDELAY 0
    AXHANG 0
    BEACON EVERY 10
    BKONDEL ON
    BLT 1 EVERY 00:30:30
    BLT 2 EVERY 00:10:00
    BLT 3 EVERY 01:20:00
    BLT 4 EVERY 01:50:00
    BREAK OFF
    BTEXT callsign-3 APRS Digipeater
    BUDLIST OFF NONE
    CANLINE $18
    CANPAC $19
    CD SOFTWARE
    CHECK 0
    CMDTIME 1
    CMSG PBBS
    COMMAND $03
    CONLIST OFF NONE
    CONMODE CONVERS
    CONOK ON
    CONPERM OFF
    CPACTIME OFF
    CR ON
    CRSUP OFF
    CSTAMP OFF
    CTEXT You are being re-routed to the PBBS
    CTRL A OFF
    CTRL B OFF
    CWID EVERY 0
    CWIDTEXT DE callsign
    DAYSTR mm/dd/yy hh:mm:ss (edit as needed)
    DAMA OFF
    DAMACHCK 18
    DBLDISC OFF
    DELETE $08
    DIGIPEAT ON
    DWAIT 0
    ECHO ON
    ESCAPE OFF
    FLOW ON
    FILTER OFF
    FRACK 4
    FULLDUP OFF
    GPSINIT
    HBAUD 1200
    HEADERLN OFF
    HID OFF
    HTEXT
    INTFACE TERMINAL
    LEDS ON
    LCOK ON
    LFADD ON
    LFSUP OFF
    LLIST OFF NONE
    LT 1 !3823.74NN12041.37W#PHG0000/A=000480 beacon message (Note 1: /A=xxxxxx is your altitude. This is optional)
    LT 2 !3823.74NN12041.37W#PHG0000/A=000480 beacon message (Note 2: Edit the beacon message to suit your needs)
    LT 3 !3823.74NN12041.37W#PHG0000/A=000480 beacon message (Note 3: PHG settings are explained at end of this document)
    LT 4 !3823.74NN12041.37W#PHG0000/A=000480 beacon message
    (example: LT 1 !4251.96NS07117.84W#PHG6570/A=000480 Ryan Hill; South Derry, NH
    LT 1 - 4 should all be the same. The first set of numbers are your latitute and longitude. (Important-make sure that the ! character is in front of first digit) the seconds are in decimal.
    ie: 15 seconds would be entered .25 30 seconds as .50 etc.
    LTP 1 APN83
    LTP 2 APN83
    LTP 3 APN83 VIA WIDE2-1
    LTP 4 APN83 VIA WIDE2-2
    LTRACK 0
    MONITOR ON
    MALL ON
    MAXFRAME 4
    MAXUSERS 10
    MBEACON ON
    MCON OFF
    MCOM OFF
    MHEADER ON
    MRESP OFF
    MRPT ON
    MSTAMP OFF
    MXMIT ON
    MYCALL callsign-3
    MYALIAS alias
    MYDROP 0
    MYNODE callsign-3
    MYPBBS NOPBBS
    MYREMOTE NORMT
    NDWILD OFF
    NEWMODE ON
    NOMODE OFF
    NTEXT
    NUMNODES 0
    PACLEN 0
    PACTIME AFTER 10
    PASS $16
    PASSALL OFF
    PBBS 0
    PBFORWRD NONE EVERY 0
    PBHEADER ON
    PBHOLD ON
    PBKILLFW OFF
    PBLIST OFF NONE
    PBLO NEW VARIABLE
    PBPERSON OFF
    PBREVERS ON
    PERSIST 63
    PID OFF
    PMODE CMD
    PTEXT callsign
    REDISPLA $12
    RELINK OFF
    RETRY 10
    RING ON
    RNRTIME 0
    RTEXT password string
    SCREENL 0
    SENDPAC $0D
    SLOTTIME 10
    START $11
    STOP $13
    STREAMSW $7C
    STREAMCA OFF
    STREAMEV OFF
    SUPLIST OFF
    SWP 17,17,108
    TELEMTRY 0
    TRACE OFF
    TRFLOW OFF
    TRIES 10
    TXDELAY 30
    TXFLOW OFF
    UNPROTO APKPC3
    UIDIGI ON WIDE1-1,callsign
    UIDWAIT OFF
    UIFLOOD ss,30,ID
    UITRACE WIDE,30
    USERS 1
    XFLOW OFF
    XKCHKSUM OFF
    XKPOLLED OFF
    XMITLVL 13
    XMITOK ON
    XOFF $13
    XON $11
    Antenna
    Height/Gain/
    Directivity
    The 7-byte PHG (phgd) Data Extension specifies the transmitter power,
    effective antenna height-above-average-terrain, antenna gain and antenna
    directivity. APRS uses this information to plot radio range circles around
    stations.
    The 7 characters of this Data Extension are encoded as follows:
    Characters 1–3: PHG (fixed)
    Character 4: p Power code
    Character 5: h Height code
    Character 6: g Antenna gain code
    Character 7: d Directivity code
    The PHG codes are listed in the table below:
    PHG Codes
    phgd Code: 0 1 2 3 4 5 6 7 8 9 Units
    Power 0 1 4 9 16 25 36 49 64 81 watts
    Height 10 20 40 80 160 320 640 1280 2560 5120 feet
    Gain 0 1 2 3 4 5 6 7 8 9 dB
    Directivity omni 45 90 135 180 225 270 315 360
    The height code represents the effective height of the antenna above average
    local terrain, not above ground or sea level — this is to provide a rough
    indication of the antenna’s effectiveness in the local area .
    The height code may in fact be any ASCII character 0–9 and above. This is
    so that larger heights for balloons, aircraft or satellites may be specified.
    For example:
    : is the height code for 10240 feet (approximately 1.9 miles).
    ; is the height code for 20480 feet (approximately 3.9 miles), and so on.
    The Directivity code offsets the PHG circle by one third in the indicated
    direction. This means a front-to-back ratio of 2 to 1. Most often this is used
    to indicate a favored direction or a null, even if an omni antenna is at the site.
    An example of the PHG Data Extension:
    PHG6570 means a power of 25 watts, an antenna height of 160 feet above the average local terrain,
    an antenna gain of 7 dB and maximum gain omnidirectional. PHG6573 would be same with directivity
    to the southeast or 135 degrees.
    73, Don/AC1U
  4. KE6ANM
    KE6ANM Ham Member QRZ Page
    very nice
    nice job of explaining the settings
    73 de ke6anm
