Kenwood ts-930 no am xmit.
Discussion in 'Radio Circuits, Repair & Performance' started by KM4YTW, Jul 9, 2020.
  1. KM4YTW
    KM4YTW Ham Member QRZ Page
    I just noticed last weekend that AM mode didn't work. I receive fine but when I hit the key in AM mode nothing no relay action , nothing. Stays in receive mode. Any idea where would be a likely culprit ? S1 and S2 mode switch ?
    Thanks
  2. N8YX
    N8YX Ham Member QRZ Page
    Which serial number '930?
    There were two runs, and the earlier ones implemented a different power-control scheme than the later units.
  3. KM4YTW
    It's a 600 series serial number rig . Everything works in all modes except AM transmit. Put, send button work fine . AM reception is great too.
  4. N8YX
    Look at the Carrier control and switching circuits related to AM TX. The rig puts out power on FSK and CW, right?
  5. KM4YTW
    I have no TC voltage in AM mode anywhere. Trying to figure out where this voltage originates from. Yes FSK, CW work fine. I checked all the sections on the mode switch and it checked good.
  6. KM4YTW
    Correction not TC but it's TV voltage
  7. G3YRO
    G3YRO Ham Member QRZ Page
    Personally I wouldn't bother . . . the TS-930S produces HORRIBLE AM anyway !
    It's Double Sideband with re-inserted Carrier . . . so if your audio peaks just a little too high it becomes unintelligable.
    When I want to operate AM I use my FT101E, which produces wonderful AM (sounds as good as a proper high-level modulation AM rig)
    If I really wanted to use my '930 on AM I would modulate a later stage in the rig properly, like the '101 does.
    Roger G3YRO
    K8PG likes this.
  8. KM4YTW
    Amen to the 101 I have all models except f model . I'm a huge fan of the 101 series ! It just anoys me a lot that something doesn't work. I'll get it eventually. I'll find usually by accident lol.
  9. N8YX
    There's a mod for the TS-940S which modulates the RF pre-driver by way of replacing its emitter resistor with an appropriately-spec'd audio transformer. A bit of work but according to those who have done it the results are worth the trouble.
  10. KM4YTW
    I've got it narrowed down to no TR voltage . This voltage is derived from IC11 on the signal board. It comes from a network mess of AND gates and NOT gates. The signal from IC11 pin 10 is the TR voltage which biases Q92. That's not happening.
