Canceled KENWOOD TS-870S DSP Transceiver - Nice
Discussion in 'Ham Radio Gear For Sale' started by WQ6N, Nov 14, 2017.
  1. WQ6N
    WQ6N XML Subscriber QRZ Page
    For Sale KENWOOD TS-870S DSP Transceiver.
    This has to be one of my hardest decisions to sell this radio. I purchased this unit new from HRO sometime late 2000. It has a 10mil serial number and has been rock solid. Output is 100+watts. There is a little cosmetic wear on the front lower corners, light scuff marks sides and top (from normal usage) and a small scratch or two near the rear. Electrically it is 100%. The TS-870S DSP is not a light unit and I expect that it would cost for any shipping. I do have the original box (missing the internal foam), manual, mic and power cables. I have included signalink interface cable and jumper plug to match.
    This radio is remote-able (such as RemoteHam’s server) via the built in serial interface with null-modem cable. This unit is stock with no modifications. The DSP filters provide excellent noise reduction.
    I am asking $800 firm for the unit and the buyer pay for the shipping. (Like I said above the unit is not light - 26lbs. Outer box and packing could go up to 30~35lbs). I would prefer local pickup here in San Diego if possible. Inner box is 10H 17D 20W inches.
    Non-smoking and no pets
    It will not break my heart if this transceiver does not sell.
    SPECIFICATIONS
    GENERAL
    Type:
    Amateur HF transceiver
    Frequency range:
    TX: 10-160 m + WARC
    RX: 0.1-30 MHz
    Tuning steps:
    1 / 10 / 100 Hz
    1 / 5 / 10 / 100 / 500 KHz
    1 MHz
    Mode:
    AM/FM/NFM/SSB/CW/FSK
    Channels/memory management:
    99 regular
    1 scan limit
    5 quick memory
    Lithium battery backup
    Repeater shift/offset:
    No dedicated. Use VFO A/B split instead
    Power supply:
    External 13.8 VDC ±15%
    Current drain/power consumption:
    RX: 2 A
    TX: Max 20.5 A
    Antenna impedance/connectors:
    50 ohms (20-150 ohms with ATU) / 2*SO-239
    Dimensions (W*H*D):
    330*120*334 mm (13*4.72*13.1")
    Weight:
    11.5 Kg (25 lbs)
    Other features:
    CTCSS/PL. Built-in memory keyer and ATU. IF-DSP
    RECEIVER SECTION
    Receiver system:
    Quadruple conversion superheterodyne
    1st IF: 73.05 MHz
    2nd IF: 8.83 MHz
    3rd IF: 455 KHz
    4th IF: 11.308 KHz
    Sensitivity:
    SSB/CW/FSK:
    0.1-0.5 MHz: <1 uV
    0.5-1.705 MHz: 4 uV
    1.705-30 MHz: 0.13 uV
    FM (12 dB SINAD)
    28-30 MHz: 0.25 uV
    Selectivity:
    AM Lo:
    9 KHz (-6 dB), 12 KHz (-60 dB)
    FM:
    14 KHz (-6 dB), 18 KHz (-60 dB)
    SSB Lo:
    2.3 KHz (-6 dB), 3.3 KHz (-60 dB)
    CW:
    200 Hz (-6 dB), 450 Hz (-60 dB)
    FSK:
    500 Hz (-6 dB), 1 KHz (-60 dB)
    Image rejection:
    1.8-30 MHz 80 dB
    AF output power/speaker:
    1.5 W at 10% distortion / 8 ohms
    External speaker connector:
    TRANSMITTER SECTION
    RF output power:
    Max 100 W (AM 25 W)
    Modulation system:
    AM: Low level
    FM: Reactance
    SSB: Balanced
    Max FM deviation:
    FM: ±5 KHz
    NFM: ±2.5 KHz
    Spurious emissions:
    Less than -60 dB
    Microphone impedance/connector:
    600 ohms / 8-pin
    MISCELLANEOUS
    Manufactured:
    July of 2000
    Japan, 1995-2004 (Discontinued)
    Modifications:
    None
    Options/Accessories:
    AT-300 - External automatic antenna tuner
    DRU-3 - Digital recording unit
    HS-5 - Deluxe headphones
    HS-6 - Small headphones
    IF-232C - Interface unit
    LF-30A - Low-pass filter
    MC_43S - Standard hand microphone with up/down buttons
    MC-60A - Deluxe desk microphone
    MC-80 - Desk microphone
    MC-85 - Multi-function desk microphone
    MC-90 - DSP-compatible desk microphone
    PC-1A - Phone patch controller
    PG-2Z - DC cable
    PS-52 - Heavy duty PSU. 13.8 VDC, 22.5 A
    SM-230 - Station monitor
    SO-2 - TCXO
    SP-31 - External speaker
    SW-2100 - SWR/Power meter
    VS-2 - Voice synthesizer unit
    K5MTY likes this.
  2. WQ6N
    Wouldn't you know it, forgot to add the fact that there is no returns due to part swappers and sold AS-IS. So if you need further information just ask and I will do my best to answer.
  3. WQ6N
    I will also consider swapping straight across for an operational Ameritron ALS-500RM mobile HF amp.
  4. WQ6N
    Cancelled
    No broken hearts here...
  5. QRZ
    Important Rules
    Have you read our Swapmeet Safety Rules?
    This forum enforces a set of buying/selling safety rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Our moderators review every post in this forum and will flag or delete those that do not conform.
