Kenwood TS-590SG is not recognised by PC using USB cable
Discussion in 'General Technical Questions and Answers' started by VE6LXK, Mar 24, 2020.
ad: QSOToday-1
  1. VE6LXK
    VE6LXK Ham Member QRZ Page
    I'm hooking up my Kenwood TS590SG to my windows 10 PC and have downloaded the Virtual Com Port Driver CP210X and am not having any response after unzipped and expanded and installed please advise thanks
  2. W1FBV
    W1FBV Ham Member QRZ Page
    Try unplugging the cable at the computer and then plug it back in. (That is about the extent of my technical skills.)
  3. SA4MDN
    SA4MDN Ham Member QRZ Page
    install com port drivers before plugging in radio, it can mess things up if the radio is plugged in when installing the drivers, if you plugged radio in after installing the drivers check your com port settings match the settings in the radio, ie, baud speed etc.
  4. VE6LXK
    Thanks for the reply I tried different things like that it seems the Virtual Com Port Driver doesn't show up in Device Manager I'm hoping somebody else dealt with this issue and has the resolve
  5. KA9JLM
    Run the driver installation as "Administrator" before connecting the radio.
    Do not let Win 10 find/install the wrong drivers automatically.
  6. W1BR
  7. KB0MNM
    KB0MNM Ham Member QRZ Page
    Experience tells me that it is sometimes necessary to delete drivers and re-install them. Of course, you may wish to carefully examine the system "Device Manager" for the names of these files and make back-ups before proceeding to delete them. The hardware 'Device Manager' has also been described as "Device Mangler" because it is possible to do more harm than good with it. A 'back-up' ( older copy ) copy of your operating system would not have the recent USB changes, yet may also be missing a recent 'security update'. When economically possible, use an external USB hard or solid state drive (SSD) to ensure that you can recover from problems such as folks describe ( KA9JLM did a good job of explaining what the root cause may be ).
  8. VE6LXK
    Thanks I've tried "Run as Administrator" and still no change. I'm even trying to use a PC running Windows 7 and am having the same results.
  9. VE6LXK
  10. AA3EE
    AA3EE Ham Member QRZ Page
    If it doesn't work on 2 different computers, I'd suspect the cable. I believe some cheap "charger" cables have only the power pair and do not include the data pair.
    KC2RGW likes this.
