Kenwood TS-570SG FT8 Setup
Discussion in 'General Technical Questions and Answers' started by KA3QOT, Jun 4, 2021.
  1. KA3QOT
    KA3QOT Ham Member QRZ Page
    Hello,
    I'm trying to use FTP on my Kenwood TS-570SG. I do have a SignaLink.
    I've tried to figure out how to do this, to no avail. Is it even doable?
    Dennis KA3QOT
  2. KG7WGX
    According to the SignaLink USB Product guide, the model number for the complete Signalink is SLUSB13K, the number for the cable is SLCAB13K, and the number for the jumper module is SLMOD13K.
    If you already have a SignaLink, order the last two to get it to work with your TS-570SG.
    If you already have the correct cable and jumper, then you have a problem with settings, not hardware.
    KA3QOT likes this.
  3. KA3QOT
    Thank you so much!
    73 de KA3QOT
  4. KS2G
    KS2G Premium Subscriber QRZ Page
  5. KA3QOT
    Thanks. But does this apply to the 570SG? These instructions are for the 590SG.
    It would be great if they did.
    Dennis
  6. KS2G
  7. KA3QOT
    KC9VFO likes this.
  8. KS2G
    Oh, my bad!
    I keep misreading your posts -- thinking that you have the '590.
    Apologies for the confusion.
    Anyway ... since the '570 does not have an internal sound card, yes you can use the SignaLink to run FT8.
    If you don't already have it, you need the cable to connect the SignaLink to the radio:
    Part #SLUSB8PD - For 8-pin DIN Data / Accessory Port Connector
    The SignaLink jumper settings for the '570 are on their web site:
    https://www.tigertronics.com/sl_wirebm.htm#KENWOOD
    TigerTronics has info on setting up WSJT-X FT8 software:
    https://tigertronics.com/pgmsetup.htm
    For more information, take at a look at:
    Getting Started with FT8
    https://gotahams.com/wp-content/uploads/2021/01/Getting-started-with-FT8.pdf
    For a video guide to using WSJT-X look at:
    Getting started with FT8
  9. KA3QOT
    Thanks so much! No apology necessary, of course.
  10. KG7WGX
    The part number listed above is for Icom rigs with an 8 pin connector, while the TS-570SG ACC2 connector is a 13 pin design.
    Also, the part number listed is for the SignaLink with cable, not just the cable. (All of the USB models look like SLUSBxxx and the cable only models look like SLCABxxx.)
    The best idea is to go to the Tigertronics site and download their product guide, then look up your radio. Then you won't have any doubt.
ad: M2Ant-1
