SOLD KENWOOD TS-2000X MINT!
Discussion in 'Ham Radio Gear For Sale' started by KF2C, Nov 29, 2018.
  1. KF2C
    KF2C QRZ Lifetime Member #143 Platinum Subscriber Life Member QRZ Page
    Up for your consideration is a mint Kenwood TS-2000 X Transceiver, Base, All-Mode Multi-Band, HF/VHF/UHF/ 1.2 GHz, DSP, Built-In ATU, TS-2000X original Box Mic And Manual.
    The rig is in mint condition and lightly use.
    should you have any question please contact me by phone or email
    917-709-7987 - carloskf2c@gmail.com
    priced to sell $ 1,600 shipped to you in USA
    73s De KF2C
    Carlos
    TS-2000X general features:
    * Built-in UT-20 Module for 1.2 GHz operation
    * True IF/stage main band DSP, Sub-band AF stage DSP
    * Sub-receiver for 144/440/1.2 GHz (FM/AM)
    * Razor-sharp 50 Hz DSP filter for CW
    * DX Packet Cluster Tune (P.C.T.)
    * Built-in 9600/1200 bps TNC for DX Packet Cluster Tune and Sky Command II Plus
    * Dual receive: HF-V/U, V/V, V/U, U/U
    * 100 watts HF, 6 and 2 meters, 50 watts 70cm, 10 watts 1.2 GHz
    * Built-in ATU HF/6 meters
    * Built-in RS-232
    * Built-in TCXO, 0.5 PPM stability
    * CTCSS and DCS encode/decode
    * Electronic memory keyer
    * Six antenna ports: 2 SO-239 HF/6m, SO-239 2m, Type N 70cm, Type N 1.2 GHz option and 1 separate HF RX RCA
    * TX: All bands 1.8 to 450.0 MHz (except 220 MHz)
    * General RX: 30 kHz to 60 MHz, 142 to 152 MHz, 420 to 450 MHz, 1240 to 1300 MHz
    * Sub RX: 118 to 174 MHz, 220 to 512 MHz
    * Modes: CW, SSB, FSK, AM, FM
    * Stability, Main: 14 degrees F to 122 F; FM plus/minus 0.5 PPM plus/minus 2 kHz, other modes: plus/minus 0.5 ppm
    * Stability, Sub: 14 degrees F to 122 F; within plus/minus 0.5 ppm plus/minus 600 Hz
    * Antenna Impedance: 50 ohms
    * ATU range: 16.7 to 150 ohms
    * Power Requirement: 13.8 Vdc
    * DC current: TX: 20.5 A max., RX: 2.6 A
    * Operating Temperature range: 14 degrees F to 122 F
    * Dimensions: 11.06 in. W x 4.21 H x 14.61 D
    Transmitter:
    * Output SSB/CW/FSK/FM: 100 W (160/2 meters) / 50 W (70cm) /10 W (23cm)
    * Output AM: 25 W (160/2 meters) / 12.5 W (70cm) / 2.5 W (23cm)
    * Spurious emissions: 160/10 meters -50 dB or less, 6 m to 70 cm band -60 dB or less, 23 cm band -50 dB or less
    * Carrier suppression (SSB) 50 dB or more
    * Unwanted sideband (modulation at 1.0 kHz): 50 dB or more
    * Frequency deviation: (FM) Wide plus/minus 5 kHz, Narrow plus/minus 2.5 kHz
    * XIT range: Plus/minus 20.0 kHz
    * Microphone Z: 600 ohms
    Receiver:
    * Main RX SSB/CW/AM/FSK: Quad Superheterodyne, FM: Triple Superheterodyne
    * Sub RX FM/AM: Double Superheterodyne
    * Sensitivity SSB/ CW/ FSK (S/N 10 dB): 0.5 to 1.705 MHz 4 uV or less, 1.705 to 24.5 MHz 0.2 uV or less, 24.5 to 54.0 MHz 0.13 uV or less, 144 to 148 MHz 0.16 uV or less, 430 to 450 MHz 0.11 uV or less, 1240 to 1300 MHz 0.11 uV or less
    * Sensitivity AM (S/N 10 dB): 0.5 to 1.705 MHz 31.6 uV or less, 1.705 to 24.5 MHz: 2.0 uV or less, 24.5 to 54.0 MHz: 1.3 uV or less, 144 to 148 MHz: 1.4 uV or less, 430 to 450 MHz: 1.0 uV or less
    * FM (12 dB SINAD): 28.0 to 54.0 MHz 0.22 mV or less, 144 to 148 MHz 0.25 mV or less, 430 to 450 MHz 0.18 mV or less
    * Image rejection Main: 70 dB or more
    * Image rejection Sub: 60 dB or more
    * Audio output (8 ohms, 10 percent distortion) 1.5 W or more
    * Audio output impedance (EXT.SP1 and EXT.SP2) 8 ohms
    73s De KF2C
    Carlos
    KA0REN, M3VPI, W7GST and 2 others like this.
  2. W8NIC
    W8NIC Ham Member QRZ Page
    how is the X model different from the regular model?
    thanks.
  3. KN8U
    KN8U Ham Member QRZ Page
    The 2000X has 1.2GHz while the 2000 tops out at 70cm
  4. VE4NSA
    VE4NSA Ham Member QRZ Page
    Serial number please!
  5. KF2C
    SOLD!!!
  6. QRZ
    Important Rules
    Have you read the Swapmeet Rules?
    This forum enforces a set of buying/selling rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Got questons? Contact our moderation team here...
    All Sellers Must Be Verified As of July 1, 2019, only Verified Users are permitted to post in this forum.
