kenwood tm-d710e crossband
Discussion in 'General Technical Questions and Answers' started by 2E0OKC, Jan 13, 2019.
  1. 2E0OKC
    2E0OKC Ham Member QRZ Page
    hi, all I know this rig will not crossband as its the e-version.
    but i did come across this page
    https://skyblg.wordpress.com/2017/01/15/tm-d710e-mod-cross-band-extended-tx/
    iv translated it and it says.
    TM-D710 has two models A and E. The E model (European version) does not have a cross band repeater.
    I don't know if it's necessary, but who knows when it's gonna be necessary. Unfortunately, there is nothing to do with this feature. The device needs to open and make a small operation.
    We open the top cover of the device (4 screws on 4 sides, 4 on top
    ). Carefully remove the module (with sockets, pulling up).
    When you remove the module, you will see 1 and 2 at the bottom of the socket. Number 2 ( R654 ) must be empty.
    You need to install a 0 (zero) ohm resistor here. (or short circuit with a wire part)
    When the device is switched on, there is a resistor (1) in the same sequence ( R658 )
    Note that when you perform these operations and turn on the device, all settings and memory will be reset. [​IMG]
    When you enter the menu, it should be opened after 402 under the repeater!
    the pcb board you can see on the site
    has this works for anyone
    kind regards all
