Kenwood TM-D710A GPS install
Discussion in 'Mobile Radio Systems' started by VA6KGS, Jul 30, 2020.
ad: QSOToday-1
  1. VA6KGS
    VA6KGS Ham Member QRZ Page
    I took the the instructions that Dave Santoro W2DHS posted on creating a TM-d710G of sorts and slighty modified them keeping the puck from inside the gps inside the control head
    http://www.w2dhs.com/2016/07/07/adding-gps-to-a-kenwood-rc-d710-and-possibly-tm-d710/
    I did run into problems with the GPS puck iI had been using for years where it would loose its GPS fix so i swapped it out for a new one after a few days, some dremel work remains but it does fit inside the control head right where the mount clips in.
    My Control head and old BR-355S4
    [​IMG]20200724-DSC07397 by Kevin Stuparyk, on Flickr
    [​IMG]20200724-DSC07398 by Kevin Stuparyk, on Flickr
    GPS itself pops right out of its housing
    [​IMG]20200724-DSC07406 by Kevin Stuparyk, on Flickr
    GPS has a nice connector on the wires, and with enough cable insulation removed the whole thing slide out of the housing
    [​IMG]20200724-DSC07409 by Kevin Stuparyk, on Flickr
    [​IMG]20200724-DSC07410 by Kevin Stuparyk, on Flickr
    I used a pair of needle nose pliers to unscrew the brass rings from the pots on the front
    [​IMG]20200724-DSC07404 by Kevin Stuparyk, on Flickr
    Cover removed
    [​IMG]20200724-DSC07402 by Kevin Stuparyk, on Flickr
    Original placment
    [​IMG]20200724-DSC07412 by Kevin Stuparyk, on Flickr
    My amateur soldering job, I forgot to take a picture of the other side of the board where the data connection from the gps is made
    [​IMG]20200725-DSC07421 by Kevin Stuparyk, on Flickr
    Crop in of the +5V and grounds
    [​IMG]20200725-DSC07421-2 by Kevin Stuparyk, on Flickr
    Back together
    [​IMG]20200725-DSC07426 by Kevin Stuparyk, on Flickr
    Success
    [​IMG]20200725-DSC07580 by Kevin Stuparyk, on Flickr
    the new gps, Still a BR355-S4 ordered off amazon that i swapped out while camping. its slightly Thicker with a larger antenna, same wire connector though.
    [​IMG]115929040_841679249693187_1908759811022027342_n by Kevin Stuparyk, on Flickr[​IMG]116135306_285274439590921_7928197432765717859_n by Kevin Stuparyk, on Flickr
    [​IMG]116352574_2735247573379683_7920258662661966975_n by Kevin Stuparyk, on Flickr
    Success with the new chip
    [​IMG]Screenshot_64 by Kevin Stuparyk, on Flickr
    KX4O, KC9ONY, K3XR and 1 other person like this.
  2. KK9W
    KK9W Ham Member QRZ Page
    Excellent job! I have a D710A and have been using a Deluo GPS puck with a mess of wire, adapter cables and an old Cingular Wireless cigarette lighter plug phone charger wired in to power it. Luckily most of it is hidden and it's been a work horse for 13+ years.
  3. KB0MNM
    KB0MNM Ham Member QRZ Page
    Nice work, down to the battery placement. Maybe you might want to note that in the 'notes' section of the paper manual for future reference. While I have your attention, you may want to check out a post about "Curious GPS Interference" in the General Announcements. ( Alternately, see globalfishingwatch.org/data-blog/circling-above-point-reyes/ regarding possible AIS or more likely, GPS spoofing ). Keep your eyes on the road!
