Kenwood MCP Software
Discussion in 'Computers, Hardware, and Operating Systems' started by KK4UDO, Aug 24, 2017.
  1. KK4UDO
    KK4UDO Ham Member QRZ Page
    I'm trying with no luck to get the Kenwood MCP software working with my new-to-me TM-D700A. I'm using a Prolific USB t0 Serial cable that I have used before with Cisco gear with no problems. I am using a straight-through DB9M - DB9F connector with a "gender bender" on the end to convert to dual female plugs.
    The usb to serial device is recognized in device manager. I have tried setting COM port to both 1 and 2, and set the Baud Rate to 9600 (matches radio setting) and Flow Control to Xon / Xoff (along with the default of NONE) per a post I saw online. I have also tried using chirp, both are unsuccessful.
    Any tips so I can download/upload memories and settings vs having to go through manually and program each one?
  2. KA9JLM
    You need a null modem connection.
    T and R need to be swapped.
    Good Luck.
  3. KK4UDO
    I'm willing to try anything at this point, but I've read specifically that you do NOT need a null modem cable.
    From the kenwood MCP download site:
    I'll wire up a null modem and give that a shot.
  4. KK4UDO
    Just a quick update in case anyone else has problems. I ordered this and it worked perfectly.
    KA9JLM likes this.
