Kenwood KPG-46 Cable Pinout
Discussion in 'General Technical Questions and Answers' started by ZS1F, Nov 13, 2019.
  1. ZS1F
    ZS1F Ham Member QRZ Page
    Hi All
    Hope that one of you guys can assist with the correct pin-out for the Kenwood KPG-46 cable on the USB side (wires came loose in transit).
    Thanking You.
    Regards
    Andre ZS1F
  2. W9GB
    USB 1.1 and 2.0 Connectors have a Standard for Cable wiring and Color.
    That does not mean your KPG-46 cable mfg. followed the Standard.
    279225BD-3942-4C84-B5A9-8C44CA620FE8.png E3375D51-63B9-4B5D-AA89-7C16E568C876.png
    Pin 1 : V+ : Power (+5 VDC), RED
    Pin 2 : D- : Data - , WHITE
    Pin 3 : D+ : Data + , GREEN
    Pin 4 : V- : Power Ground (GND), BLACK
    SHELL : Shield/Drain Wire of cable
    http://www.qualtekusa.com/images/Cable Assemblies/PDF_2/3021005-03.pdf
    Repeater Builders : Kenwood Page
    http://www.repeater-builder.com/kenwood/kenwood-index.html
    Kenwood numbers the pins backward from UTP Ethernet standard (TIA/EIA 568)
    Sadly, this has been a common Japanese error (mirror-image) with connectors, since the 1970s.
    http://www.repeater-builder.com/kenwood/kenwood-software-and-cable-list.html
    The Kenwood KPG-4 and the KPG-46 programming cables are the exact same unit except for the RJ connector on the radio end of the cable.
    The KPG-4 has a 6-pin (RJ-11 / RJ-12-style) connector.
    The earlier KPG-46 has an 8-pin connector (RJ-45 style) and the center 6 pins are wired the same and the outer 2 pins are not used.
    If you are careful the 6-pin KPG-4 will work perfectly in the 8-pin mic jack. The plastic tab should only let you put the 6-pin plug into the middle of the 8-pin jack since pins 1 and 8 on the 8-pin jack aren't used for programming purposes.
    Look carefully at the 6-pin plug however, some have a thicker shoulder that will push pins 1 and 8 of the 8-pin jack up into the plastic body, bending and damaging the two pins.
    If you are going to build your own programming adapter you could copy one trick I saw - the person used a dual jack snap-in housing, mounted the perf-board inside, had a DB-9 pigtail coming out of one side, a connector for a 12vDC wall wart on the same side, and both 6-pin and 8-pin jacks snapped into the housing. The two jacks were wired so he could use a common 6-pin phone cable to connect to to the 6-pin radios, and a common ethernet patch cord for the 8-pin radios. Or you could build it with one connector, and build an adapter starting with a 6-pin RJ-12 jack wired to a stub of a common 8-pin RJ45 ethernet cable.
    Schematic and Pinouts of Kenwood KPG-4 / KPG-46 cable (RS-232 to Radio)
    http://www.repeater-builder.com/kenwood/pix/kpg-4-and-kpg-46-programming-cable.gif
  3. ZS1F
    @W9GB thank you so much for all the info! Much appreciated.
    Greetings from Cape Town, South Africa
    Andre ZS1F
