Kenwood 590s / SDR / MFJ 1708
Discussion in 'Rig Control, Prop., Cluster, & Other Software' started by NN2X, Jul 5, 2018.
Tags:
  1. NN2X
    NN2X Premium Subscriber QRZ Page
    Hello Fellow Ham Operators
    I have the following equipment
    • Kenwood 590s,
    • SDR Pro
    • MFJ 1708..
    I saw somewhere that there is ability to sync the Kenwood 590s and sync with SDR, meaning when you turn the dial on the transceiver, the SDR would move as well (Or visa versa)
    For the life of me, I can't find that info, I saw it before, and I noted I had to down load special software for USB support to make the Kenwood 590s and SDR in Sync...
    Look forward to your responses!
    NN2X, Tom
  2. AA6YQ
    AA6YQ XML Subscriber QRZ Page
    Commander, the transceiver control component of the free-ware DXLab Suite, provides a secondary CAT port you can use to interact with an SDR-driven panoramic display with bidirectional frequency synchronization. Step-by-step instructions are here.
    The first step would be to configure Commander to control your TS-590S via Commander's primary CAT port.
    If you need assistance, post a message on the DXLab Discussion Group, where all questions are welcome no matter how many times they may have already been asked and answered.
  3. N5AF
    N5AF Premium Subscriber QRZ Page
    Tom,
    Two helpful videos linked below. The 590S configuration for rig control isn't significantly different than the 590SG. All you need is the proper USB cable. I recently "remote" assisted in the configuration of a older 590S. (I own an SG).
    https://tinyurl.com/ybzg9tq6
    https://tinyurl.com/y9pk9sl3
    Any menu references from the 590SG vs 590S menus can be figured out here: http://www.g3nrw.net/ts-590-files/TechNote_TS-590_Menu_Conversion_v1.0.pdf
    Kenwood USB Driver: http://www.kenwood.com/i/products/info/amateur/software_download.html
    Good Quality USB Cable: https://www.amazon.com/Tripp-Lite-H...=2025&creative=165953&creativeASIN=B003MQ29B2
    And as always, Google searches are your friend. Lots of info out there.
