Just a little PSK/Digital Help
Discussion in 'General Technical Questions and Answers' started by W9UND, Feb 10, 2021.
  1. W9UND
    W9UND Ham Member QRZ Page
    I have been trying without ANY success just to "see" some PSK transmissions. I have my Yaesu (FT991) hooked into my computer. Because I'm seeing the signals, I'm assuming I have my com port set up correctly.
    I have attached a screenshot from Digipan to show what I'm seeing. I ALWAYS get nothing but gobbledygook no matter what I do. I've tried switching modes. I've tried playing with the levels of the input....I just can't figure it out. I tried going step-by-step through the AARL digital book on how to set everything up, but just no success.
    I'm just wondering if someone can just give a suggestion on what I should try. Am I not setting a filter correctly? I keep switching between upper/lower data modes and everything else. But, all I ever see is the same gobbledygook! I know so many things can be to blame, but I was just looking for some other suggestions. Thanks!
    KD9BDT
  2. NE3R
    NE3R Ham Member QRZ Page
    not a lot to go on here.
    1, are you sure your computer microphone isn't picking up audio from your radio? It is a common mistake to configure the radio's input to the computer mic instead of the correct audio device.
    2, what frequency is your radio tuned to (you'll see plenty of signal on an FT8 frequency, but digipan won't decode it)
    3, is your radio set to a data mode?
  3. W9UND
    Thanks. I'm going to play with the computer settings a bit more. I have tried all the digital modes. You're seeing 20m here.
  4. KD8DEY
    KD8DEY Ham Member QRZ Page
    Are you using the USB cable for the Audio connection?
    SCU-17 drivers installed..
    Mode on the radio set to Digital-USB...
    checked the program source preferences in the windows sound settings advanced menu...
  5. KI5WW
    KI5WW Ham Member QRZ Page
    The pic provided doesn’t look like a psk signal.
  6. KI5WW
    Select mode then psk 31. Tune to 14.070 usb.
  7. KI5WW
    May not be any activity at the moment.
  8. K3XR
    K3XR Ham Member QRZ Page
    Can you get to 7070 USB (not LSB) and look for a signal that looks something like a railroad track on the waterfall? That's the best I can do to help you ID a PSK signal.
  9. KI5WW
    This is what psk looks like on a busy day. And this is using digipan.
  10. W9UND
    Thanks for all the help. I know it's a hard question to answer. I'm going to have another go at it tonight. Maybe I'll hear some of you! I appreciate the screen shot of DigiPan!
