JT9 - WOW! Very sensitive indeed!
Discussion in 'Working Different Modes' started by W7UUU, Aug 18, 2014.
  1. KV4RH
    KV4RH Ham Member QRZ Page
    You've inspired me. Been doing a lot of JT65 while I'm in the shack doing school work or browsing ebay or whatever other menial computer task. I moved up the few kc to the JT9 guys and hvae made a few contacts today. Been dialing back the power, and came damn close to the 1000 mi/watt goal earlier today with some eastern europe on 5W. Calling cq now at 1W to see where I get spotted.
  2. K4VLF
    K4VLF Ham Member QRZ Page
    Does JT9 use a similar protocol to JT65? Meaning, TX one minute, RX the next? 13 characters at a time kinds of stuff??
    TNX
    Dave
  3. AA8TA
    AA8TA Ham Member QRZ Page
    Yes, it's the same format.
  4. W7UUU
    47 seconds I believe for both modes, but yeah - it's pretty much the same. But in JT65 the tones are
    pronounced and you can hear them and this it takes up quite a bit more bandwidth.
    JT9 the tones are BARELY audible - sounds more like a steady tone (I monitor my own
    sending on the FT-950). But same 13 characters, same protocols, etc. etc. And the
    WSJT-X software is much more sophisticated than the JT65A software.... and it does
    both modes - at the SAME TIME if you want! (requires the use of "split" on your transceiver
    but the software does all the work - you just check the right boxes).
    JT9 is VASTLY better at QRP in my own experience - orders of magnitude better! 1-2 watts
    and I've been working state after state. On JT65 for my WAS Digital Endorsement, many
    of the QSOs were at 20-50 watts - turning up the gas until the contact was made. So far,
    I've not used more than FIVE watts on JT9 and most of my Q's are at 1-2 watts.
    Dave
    W7UUU
  5. N1EN
    N1EN Premium Subscriber QRZ Page
    If you want real fun with JT9... awhile back, just for yuks, I turned my K3 down to 0.1W (didn't check it with a meter....just minimum power). I was able to make transcontinental contacts, and I did see myself heard in Europe on pskreporter, using a Carolina Windom.
  6. W0JMP
    W0JMP XML Subscriber QRZ Page
    Reminds of the inverse of a famous Yogi Berra quote: "Nobody goes to Coney Island anymore; it is too crowded."
    I try to use it every day and like Dave says, it is crazy efficient. The more we use it, the more other people will use it.
    My IC-7600 will only go down to 900 miliwatts, but I am adding a digital interface to my K2 so I can run lower power. I also just ordered an Icom IC-7100. I wonder how low it will go?
    Dan, W0JMP
  7. W7UUU
    I'm a FAN! It's just downright creepy how well it works :)
    Stuck in Raleigh, NC for 3 days on business :(
    Dave
    W7UUU
  8. AA8TA
    Bands sure are noisy tonight. S7 on 20 meters. Geomagnetic storm and some thunderstorms around here. Had to shut down. At least I got W1AW in my home state before the noise took over. I'm hoping somebody in North Dakota puts W1AW on JT65 sometime over the next several days - need ND for WAS/JT65.
  9. W0JMP
    Dave, as much as you travel, ya gotta get something to operate from those hotel rooms. JT9 is perfect for that.
    They always asked me why I wanted the top floor ;-)
    Danny, W0JMP
  10. W7UUU
    Indeed! I've been thinking about that lately.... just might have to put a travel rig together
    Dave
    W7UUU
ad: Stlouis-1
