JT65 and unknown callsigns
Discussion in 'Mac Ham Radio on macOS & iOS' started by OK8LEO, May 21, 2016.
  1. OK8LEO
    OK8LEO Ham Member QRZ Page
    i received this morning on 20 meter the following message
    nz1zje jd8wej co 21. screen dump attached.
    I try to trace the callsigns but failed. Was this a hoax call or data collation?
    Did you had the same situation?
  2. W7CJD
    W7CJD Ham Member QRZ Page
    On the basis of JT65 just over the border, the whole point of JT65 and data mode is garbled callsigns.
  3. W1VT
    W1VT Ham Member QRZ Page
    JT65 is designed to handle weak, not strong signals. Perhaps the error is caused by soundcard overload? Too much audio into the soundcard resulting in -1 signals--which is the maximum signal strength JT65 can report. There are at least three places to adjust the audio--at the rig, with Windows, and with the WSJT program.
  4. WJ4U
    WJ4U Subscriber QRZ Page
    Gibberish. No NZ1 calls with three letter suffix and grid CO21 is off the coast of British Columbia, Canada.
    *edit* W1VT makes a good point about the RX level.
  5. OK8LEO
    at w1vt
    Thanks for the feedback. I have the audio in always around 5 dB and I can see on the water fall is the signals are too high nodulated
    Also i expect when the message is not correctly decoded I see then * or other strange characters
    PS JT65 works not only on windows :)
    Mac here in operation.
