ad: jefatech
Issue #24: Cool Devices to Learn CW
Discussion in 'Trials and Errors - Ham Life with an Amateur' started by W7DGJ, Jul 26, 2023.
  1. KL7KN
    KL7KN Ham Member QRZ Page
    To add for those not familiar with the "MMX System'
    PreppComm DMX-40 - Morse Code Decoding QRP Ham Radio - YouTube
    this has a few screen shots of the decoding in action.
    Josh also talks of the use as a decoder with a rig already at hand.
    I've covered this device elsewhere on the web and also here on the Zed (Better keyboard CW for Technicians | Page 3 | QRZ Forums #32)
    where I noted:
    "The higher frequency audio feed caught my attention. For many ham rigs, the 1300Hz would be right at the edge of most RX passbands/filters & ditto for many DSP filers."
    This high audio frequency input is what sets this decoder system apart from others on the market - IMO. This 'feature' all but eliminates the use of a classic CW filter - unless you have a robust RIT function in your rig. I can see how this would work to aid in processing the CW signal to be decoded. This argues for the 'use widest BW setting' instruction.
    As for the claim to decode at or below the noise floor - also credible, as very small, standalone PSK31 systems, like the NUE-PSK modem routinely does this. I upgraded my NUE-PSK modem with the CW software and setting the input to a higher audio frequency does seem to help - much to my surprise.
    Much of the settings are quite 'fiddly' - trying to match the rigs RX to the modem, but it does work fairly well. Understanding the RIT function of your rig is key here.
    The device appears to be well made as seen on this teardown video - PrepComm MMX TearDown - Keyboard CW? - YouTube
    For the ARS CW purist, the system is a non-starter.
    For a 'prepper' that just wants a tool to communicate with friends/family, it would seem to be a ready market.... It is most certainly cheaper than a satphone setup.
    As always - YMMV.
  2. KL7KN
    Eric-
    Thanks for dropping in on the discussion.
    Any chance you would share a schematic of the MMX?
    The "AI decoder" meme was covered, quite extensively - here:
    The rise of the robot AI CW decoders | QRZ Forums
  3. K8XG
    K8XG Ham Member QRZ Page
    And like you mentioned, when you move to a new signal, you need to press the space bar so it restarts it's algorithm to determine how best to decode the signal. Another point is it's perfect pass band for decoding is 1300hz, to get thru the noise better. That means if your using it on the side of say a G90 set to 700hz CW ; you have to use the RIT on the G90 to get that green dot working at 1300hz.
    W7DGJ likes this.
  4. K8XG
    If a Schematic would be published, his market would be stolen in China with clones that are of low quality just like all the other small QRP transmitters.
    K8PG and KL7KN like this.
  5. W7DGJ
    W7DGJ Platinum Subscriber Platinum Subscriber QRZ Page
    Yes, I don't know why we hams expect this from for-profit companies. Makes no sense to give away the candy store. I was impressed with one Chinese company (Venus) who actually published the schematic of THEIR little QRP radio, which one of our QRZ members helped write up a manual for. That's impressive. A quick glance however and it looks to me like Venus took one of the MTR radios and just reverse engineered it. Dave
  6. KL7KN
    You looked wrong. Sorry, Dave... To there was no reverse engineering from Venus. One example - the bfo injection frequency is generated by the DDS chip, directly. The Mt Topper has a tunable bfo oscillator.
    The input voltage is wider for the SW3B, and the PA amplifier handles SWR much better than Steve’s rig. The tuning rates are far different and so on.
    **The software is completely different between the rigs.**
    Also, I didn't help write the manual, I wrote the entire manual - based on my earlier manual for the MFJ-920o/HS1A. Hate to sound peckish, but as a professional technical writer, it is a matter of taking pride in my own personal effort.
    FWIW, Steve Weber has published the schematic for the Mt Topper, and other rigs, none of which have shown up as a ChiCom clone. Why? **They are unable to copy the software**.
    The now defunct DCW1 qrp rig made it to the preproduction prototype stage....but it failed to go into production because they could not successfully steal the software. I sent the only two DCW1 units to make it out of China to @W7UUU , who still has them.
    The NUE PSK was cloned, using the open-source software in the clone...and now the Chinese company is gone and the NUE PSK modem is no longer...they are a true victim of Chinese IP theft.
    Both the SW3B and the Mt Topper are single conversion, multi band rigs using the NE602/SA 612 chip.
    Just like the earlier KX1 of Elecraft fame. IMO, the failed DCW1 was likely going to try to replicate the KX1, but failed in the software....
    To my earlier point — the folks that sell the MMX would - IMO - face no threat in publishing the radio schematic, as the **software** is the real value of their product. I’ve seen ZERO Chinese clones that have successfully hijacked proprietary software. Only open-source software...a la the (tr)uSDX saga...and the McHF, the NUE PSK and on and on.
    As I've noted before, the target market, so-called preppers, usually lack the skills, training and from my conversations there, frankly, the interest to do their own maintenance or repairs. But without the schematic, neither maintenance nor repair is going to be possible for the average non-hambone owner.
    This is why, in my postings to these so-called prepper sites, I extoll the virtues of ARS HF kit radios that provide complete technical data. If nothing else, these prepper type would at least have a chance on the repair of a malfunctioning rig.
    /rant
    N1PCZ and W7DGJ like this.
  7. W7DGJ
    Thanks for the clarification Don. I think a part of this is the assumption (so often true) that the theft of ideas and inventions is rampant there. My apologies to Venus, Dave
    KL7KN likes this.
  8. KL7KN
    Thank you. Accusations of IP theft are a big deal...and yea, the term Chinese Copy is valid, from the many cloned products sold here.
  9. W7IUT
    W7IUT Ham Member QRZ Page
    Have carefully read and digested the previous comments on both Morserino and MMX----as always, exposure of new products generates multiple examples of personal experience. That said, I will submit my relatively long experience with my MMX20/40/80. I was first licensed in 1953 as WN7iut---, I simply had and have a major preference for CW. I did a lot of loner practice in early years and was very fortunate to have an elmer (SK) who was an ex-navy and RCA commercial telegrapher---he did 50 wpm with ease! He was a very competent teacher! I followed his suggestions and got my license. I have NEVER become a high speed CW hotshot! I can send and follow near 100% at 20-25 wpm. I bought the MMX20/40/80 and can tell you it is very friendly to the shaky 94 year old fist that is me. The MMX DOES provide a genuine incentive to hearing and associating the sound and rhythm that is Morse code. The device has been a joy as I am devoted to QRP and the MMX at around 4 watts is simply fun to report to a contact that is 2000 mile away. I have no experience with the Morserino but the MMX is a much needed boot to retain and magnify the fact that ancient CW is simply unique, irreplaceable and sticks in my mind that allowed me to make 77 critical CW message transfers for ten days in the 1964 Anchorage, Alaska devastating earthquake. I recommend the MMX and CW! 73 from Bob W7iut.
    KX6J, WA1LBK and W7DGJ like this.
  10. W7DGJ
    Thanks Bob. Great comments, much appreciated. Dave, W7DGJ
    KX6J likes this.
  11. AF7YQ
    AF7YQ Ham Member QRZ Page
    Well, I would not expect you to use our products - they were not designed for you! We did not build this for people who already know Morse code! If you already have your brain trained, well, then... that is what you should use.
    Yes, band noise can make you "not hear." If there is band noise and a fading signal, your ears will stop hearing before the decoder stops hearing. That is simply because the decoder does not hear 99% of the noise, which is eliminated in the decoding process. 99% is probably the wrong number, maybe 95%, dunno. But the decoder separates noise from signal, not perfectly, but better than you can when the S/N is really bad - to the point where the signal has faded out and you can no longer hear it. If you think this can't happen, you don't understand your ears. I know it happens to hams all the time, and they think the signal has completely faded out (because they can't hear it) but it is often still there and if it is, the decoder can decode it, assuming it is not below its hearing lower limit.
    Anyway, it is only an interesting point, and it is amazing when it happens to you (even though I invented it, when I see that happen, t blows my mind). It is an infrequent event, not the main event, which is reliable decoding with noise (and you can hear the signal).
    W7DGJ likes this.
  12. W7DGJ
    The "noise doesn't matter" idea certainly is proven out in the work that Joe did in developing our digital modes! Dave, W7DGJ
  13. W4NNF
    W4NNF Premium Subscriber QRZ Page
    I'm sure some people...those who want to use Morse code, but not necessarily learn it, will like your radio. After having taught the code for years, however, I am skeptical it's a good way to learn it.
    HOWEVER...I would be the last person to oppose anything that causes more people to become interested in the code in any shape, form, or fashion! Good luck!
    KX6J likes this.
  14. W7DGJ
    Your last line is the right attitude to have on these devices, Rod. At least you're open, still a skeptic, but open for more people to join the CW section of the ham bands. I love the effect that the two big morse classes have had on the hobby (Long Island and CW Acad.) and anticipate that there are just some users who will ALWAYS gravitate to a technology method as opposed to the practice-practice method of our Dads and Elmers. By having all this available, and the discussion here and elsewhere, we can keep waving the CW banner. Dave
    W4NNF likes this.
  15. KW4TI
    KW4TI Ham Member QRZ Page
    One thing that might be of interest is a transceiver I designed for digital modes communication that also has a built-in CW encoder and decoder:
    http://www.github.com/profdc9/RFBitBanger
    It is built with the minimum of specialized parts that would likely be available in a hobbyist junkbox. It is a prepper radio in the sense that if there is a supply chain disruption, this radio relies on the fewest specialized parts that might be difficult to get to repair the radio.
    I wrote the CW decoder I use. It's based on a narrowband FIR filter at 667 Hz. The decoder builds a moving-average histogram of mark and space delays and uses these to determine the current cutoffs between dit/dah and interelement / interword delays. It accumulates elements and then does a best fit of the elements to a particular symbol. There is a delay between receiving and decoding to allow the histogram to fill and provide a sufficient sample set to distinguish the elements. A keyboard can also be plugged into the radio if you want to send that way rather than use a straight or iambic key. There are also other features such as built-in digital modes (a new digital-mode that I designed) as well as SSB support in the same manner as the uSDX.
    I am giving a presentation on it at QSO Today on the 9th-10th of September.
    Dan
    KW4TI
    PY2NEA, DL4AD, W7DGJ and 1 other person like this.
