Same here (don’t ask). Also a Frisbee dog toy. Nothing antenna related yet. The trees aren’t quite big enough.
In the very large pine tree on the SW corner of my property, there is a big Model Airplane..... that just mysteriously appeared there a few months ago. Several storms later, it's all beat to pieces but giblets of wing covering can still be seen, fluttering from one of the branches. I've looked over the entire area, hoping to find the engine (or electric motor).... but have had no luck.
I have several sinkers and 20 pound fishing line pieces stuck over some trees. One of the ropes used to hoist up an antenna broke and is about 40-feet up in a tree. So, I need to get a tree climber or climb the tree when the XYL is not around to add rope to the pulley counterweight system.. I also want to have the antenna line at the other end moved up higher in a tree to get the antenna wire up at least 45-50 feet above the ground. The main problem is too much poison oak around under the trees - makes it hard to shoot lines over the trees. Right now one end is at about 50-feet, the other at about 30 feet and it slopes down hill. Getting it to a "flat top" configuration will likely help somewhat. Roger N6RGR
Squirrel poop. Had a pair of pliers up there right after I moved in 34 years ago, but they came down a long time ago.
