Interesting Tube Finds
Discussion in 'Amplitude Modulation - AM Fans' started by AC0OB, Jun 19, 2017.
  1. AC0OB
    AC0OB Subscriber QRZ Page
    I was at a Hamfest this weekend in Kansas and found the following tubes being sold from an estate. Tubes were in original cartons and packing:
    1. QTY. 1, Taylor TZ-24/DA41
    2. QTY. 2, Eimac 3C24/VT204
    This guy has done some curve tracing on the Taylor;
    http://www.dos4ever.com/uTracer3/uTracer3_pag6.html#TZ40
    AF6LJ likes this.
  2. K8ERV
    K8ERV Ham Member QRZ Page
    3C24 VT204 Eimac_crop0.jpg I think the 3C24 is the same as the 24G, my first xmitting tube. Beautiful in its simplicity.
    TOM K8ERV Montrose Colo
    AF6LJ likes this.
  3. K4KYV
    K4KYV Subscriber QRZ Page
    Triodes, about the same power level as an 807.
    AF6LJ likes this.
  4. K5UJ
    K5UJ Ham Member QRZ Page
    Here's a Taylor T155 I found at the Dayton Hamvention. I'd like to find another one like it. Taylor_T155 - 1.jpg
    N2EY and AF6LJ like this.
  5. W7TFO
    W7TFO Subscriber QRZ Page
    Every Taylor 155 I've come across was either dead or gassy.
    So gassy in fact, that my technique for ion-pumping the gas to inert state didn't work.
    But I'll save you the next one I get. Taylor gave up on the 'thin-wall' plate stuff when RCA fielded the 810 and 8000 triodes.
    73DG
    AF6LJ likes this.
  6. W7TFO
    That top Taylor is a TZ-40. A very good little triode.
    73DG
    AF6LJ likes this.
  7. AC0OB
    Good catch Tom and on the carton it is listed as 3C24 and 24G, and on the envelope it also says VT204.
    Phil
    AF6LJ likes this.
  8. K5UJ
    That's too bad. I've only done a crude filament emission test so far.
    I finished reading the Eimac file. My 40 year old Kenmore microwave oven (which has a 1 KV power supply and must weigh around 70 lbs) has a Litton magnetron in it.
  9. K4KYV
    Notice the plate and grid caps, shaped with the expansion below the cap part so you can use a screwdriver to get leverage against the connector body to pry the connectors off if necessary, without the risk of pulling the cap loose from the tube, sometimes even breaking the glass envelope.
    Tubes with a simple cylindrical metal cap and no expansion at the base, combined with those crappy ceramic-covered pull-off plate and grid caps, are a disaster waiting to happen.
    N2EY and (deleted member) like this.
  10. K5UJ
    I wondered why they did the caps with the extra umbrellas and concluded (guessed) that it had to do with the metal -- glass seal and expansion. T155 anode is carbon. It will be a bummer if it is gassy
