Incandescent Bulb HRS-7129A-Y2
Discussion in 'Radio Circuits, Repair & Performance' started by W9GB, Dec 22, 2019.
  1. W9GB
    Japanese radios historically used 12 Volt Incandescent Bulbs (Lamps) for front panel lighting.
    The HRS-7219A-Y2 was commonly used in a number of Kenwood, Icom, & Yaesu Radios.
    ... as noted a decade ago, for the Icom IC-228x radio.
    http://forums.qrz.com/index.php?threads/replacing-burned-out-lights-on-ic-228h-2m-mobile.194879/
    Mouser STOCKS this Part, CML / VCC 7219
    Mouser part number: 606-CM7219 , 82 cents (qty 1), 51 cents (qty 50).
    https://www.mouser.com/ProductDetail/VCC/7219?qs=9GEuPTpyLrg4zTItqoUnOw==
    IRONICALLY, Mouser does NOT stock the 14 Volt lamp, CML 8111 (14 Volt, 65 mA)
    which would Last Longer within 13.8 VDC powered radios.
    https://www.mouser.com/ProductDetail/VCC/8111?qs=/ha2pyFaduhA1rq42vXgDzkgy0aDhLfb5DKzXx8MEmE=
    VCC / CML 7219 Data sheet
    12 Volts, 60 mA
    https://www.mouser.com/datasheet/2/... (standard) - Sub-Midget Flange B-1064848.pdf
  2. KH6AQ
    KH6AQ Ham Member QRZ Page
    The 12 volt lamp is rated for 10,000 hours. Using the V^-16 formula a 12 volt lamp operated at 14 volts has its life reduced to 8.5%. The 10,000 hour lamp becomes an 850 hour lamp. A 33 ohm, 1/4 watts series resistor will drop the lamp voltage by 12 volts and increase lamp life to 10,000 hours.
    https://en.wikipedia.org/wiki/Lamp_rerating
