Importing problems WRL
Discussion in 'QRZ Site Community Help Center' started by KC3VLN, Mar 4, 2025.
  1. KC3VLN
    KC3VLN Ham Member QRZ Page
    I’m trying to import my WRL logbook its very small but I want to bring them in. I save them in WRL but when I import them to QRZ nothing comes over. QRZ says they successfully upload the file but no contacts.
    There seems to be field issues.
  2. KF8KI
    KF8KI QRZ Staff Engineer QRZ HQ Staff QRZ Page
    I see that you've opened a support ticket. I'll respond there too. The answer is in your import report, a snippet of which you included in your ticket:
    Error 1. Error on record: KC3WQE de KC3VLN on 2024-08-31 20:23:00. could not be imported into the specified book (). This can happen because the callsign doesnt match or the QSOs date/time is outside of the logbooks date range. Error 2. Error on record: W3AJD de KC3VLN on 2024-09-30 21:11:00. could not be imported into the specified book (). This can happen because the callsign doesnt match or the QSOs date/time is outside of the logbooks date range. Error 3. Error on record: KC3UNI de KC3VLN on 2024-10-19 00:49:00. could not be imported into the specified book (). This can happen because the callsign doesnt match or the QSOs date/time is outside of the logbooks date range.
    The start date on your logbook is 2025-03-03. This means that logbook will not accept any QSOs dated prior to 2025-03-03. If you want to log anything any earlier than that, you need to change the start date to a date before the first QSO you wish to log.
    73, Steve KF8KI
    NQ1B likes this.
  3. KC3VLN
    Thank you! I didn't realize there was a beginning date that needed to be adjusted!
    KF8KI likes this.
  4. KF8KI
    Glad I could help.
    The start date generally defaults to the date the logbook is created, so it has to be adjusted for older QSOs. No harm in doing so as long as it doesn't conflict with logs from a former holder of the callsign, if there was one.
    73, Steve KF8KI
  5. KE9AVF
    KE9AVF XML Subscriber QRZ Page
    How do I adjust the beginning date of the log book. Conversation seems to suggest that I should change the date of the QSO (which would keep it from being confirmed).
  6. KF8KI
    No. You would never change the date on a QSO. The logbook has a start and end date. The start date in the logbook must be before any QSO you wish to log. Change it in Logbook settings -> logbook properties.
    73, Steve KF8KI
ad: TinyPaddle-1
