SOLD ICOM M710 SSB HF Marine & Ham High Seas Radio Tranceiver
Discussion in 'Ham Radio Gear For Sale' started by N6LQE, Oct 19, 2019.
  1. N6LQE
    N6LQE Ham Member QRZ Page
    ICOM M710 SSB transceiver – includes Mic & factory instruction manual.
    -------------------------- $ 325.oo - OBO-+ shipping ----------------------------
    ICOM SSB radio Transceiver with Approximately 150 watts output power - also selectable to 60 watts & 20 watts.
    -------- Runs on 13.8-volts DC - plus or minus 15%. -----
    (NOTE: if you want to run this radio on 24 -V or 32- volts then a special voltage converter is needed, which are still available from ICOM - PT # PS-65/66 & if you want it to run off 120-V A/C then a ICOM power supply PT # PS-60 for that).
    Current draw: Transmit - 30 A ---- Receive - 2.5 to 3.0 Amps.
    It already has the basic Marine HF ITU Channel Frequencies programmed in from factory - both Duplex channels & Simplex channels.
    Note: 160 additional channels of user selectable HF band frequencies & those can be added or changed, if desired. Will also work on the HAM bands with those 160 programmable frequencies.
    User selectable modes of operation - Operates in voice SSB mode, CW - Morse code mode & FSK mode for those with modems for things like Sail Mail, etc.
    NOTE: No antenna & No antenna tuner, No mounting bracket, No Power cables & one little rubber foot missing on bottom corner. -- all those are still available if you want them & can be ordered.
    This is just the basic good solid ICOM Marine Single Side Band HF transceiver that gets the communications job done that your looking for to be reliable & there when it's needed.
    -----Receiver covers Frequencies 500 kHz to 29.999 MHz's .
    -----Transmitter covers all ITU marine HF band frequencies as listed:
    1.6 - 2.9999MHz
    4.0 - 4.9999 MHz
    6.0 - 6.9999 MHz
    8.0 - 8.9999 MHz
    12.0 - 13.9999 MHz
    16.0 - 17.9999 MHz
    18.0 - 19.9999 MHz
    22.0 - 22.9999 MHz
    25.0 - 27.5000 MHz -- only 60 & 20 watts on this band.
    there are 160 available additional slots for user programmable frequencies.
    ------ See Pictures Below. ---- weighs about 18 to 20 pounds or so.
    Just a good solid operationally sound SSB radio transceiver for those who go beyond VHF radio line of sight range & like the peace of mind that having the communications flexibility that a good powerful SSB transceiver like this gives you, when you’re at sea or some quite out of the way & off the beaten path anchorage as well.
    Priced reasonably @ $ 325.oo - OBO - plus shipping. -- I accept PayPal.
    ----- Located in Southern California --- zip - 93010
    Contact me at: alfa mike 8277 at yahoo dot com, or PM me here on TF.
    ----- Thank for taking the time to read this ad. -- see pictures below:
    Mike -- N6LQE
    KG4BFR and W3LES like this.
  2. N6LQE
    Unit is sold.
    Thank every one for such a great response & interest in my ad.
    Thanks QRZ.
    Mike
  3. QRZ
    Important Rules
    Have you read the Swapmeet Rules?
    This forum enforces a set of buying/selling rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Got questons? Contact our moderation team here...
    All Sellers Must Be Verified As of July 1, 2019, only Verified Users are permitted to post in this forum.
