ICOM IC-7610 HF/50Mhz All Mode Transciever
Discussion in 'The QRZ 25th Anniversary Trivia Sweepstakes Prizes' started by AA7BQ, Sep 25, 2018.
  1. AA7BQ
    AA7BQ QRZ Founder Administrator QRZ Page
    We are proud to announce that ICOM America is providing a state-of-the-art transceiver to to our sweepstakes. The IC-7610 is one of the most exciting new radios on the market today.
    From the ICOM 7610 web page...
    Faint signals are no longer a challenge for DXers and Contesters around the world, with the new IC-7610. The difference between putting the QSO in the log or trying another time is the capability of your receiver. The high performance RMDR in the IC-7610 has the ability to pick out the faintest of signals even in the presence of stronger, adjacent signals. The IC-7610 introduces dual RF direct sampling receivers. Achieving 100dB RMDR, these receivers rival that of other top-of-the-line transceivers. The IC-7610 also comes with a high-speed, high-resolution, real-time spectrum scope on a 7-inch color display.
    Output Power:
    100W (25W AM)
    RX Frequencies:
    0.030-60.00MHz
    Receiver Type:
    Direct sampling
    RF Direct Sampling System
    The IC-7610 employs an RF direct sampling system, where RF signals directly convert to digital data and then processed by the FPGA (Field-Programmable Gate Array). This process reduces distortion that naturally occurs in the various mixer stages found in traditional superhetrodyne receivers.
    The RF Direct Sampling System in the IC-7610 is capable of 110 dB* RMDR. This performance gives you the ability to pull weak signals out of the noise of strong adjacent signals. There is a difference you can actually hear as the desired signal comes out of the pileup!
    * Representative value at 2 kHz frequency separation (Received frequency: 14.2 MHz, Mode: CW, IF BW: 500 Hz)
    RMDR characteristics
    RMDR Infosheet
    Download now (PDF) >
    Independent Dual Receiver
    Whether listening to both sides of DX station running split, or looking for a multiplier on a different band or mode, the dual receivers in the IC-7610 have you covered. Two separate DIGI-SEL preselectors, two separate Band Pass Filter networks, feed two separate A/D converters into the FPGA.
    Dual receiver
    Dual Digi-Sel
    The DIGI-SEL preselectors are RF filters with sharp, narrow passband characteristics preventing Analog-to-Digital Converter overflow from large out-of-band signals when sampling the RF signals. Additionally the third and higher order IMD components are reduced. This is ideal when strong signals are received in a contest pile-up or from broadcast stations on adjacent frequencies or bands.
    BPF and preselector passband characteristics receiving on 7.22MHz
    Passband characteristics between the antenna and the preselector (at the preselector output)
    Large Color Touch Screen
    The large 7" color TFT touch LCD offers intuitive operation of functions, settings, and various operational visual aids such as dual spectrum scope aligned vertically or horizontally, simulated analog meters and RTTY, PSK31/63 mode decoded messages.
    The combination of the touch screen and the multi-dial knob offers quick and smooth operation. When you push the multi-dial knob, menu items are shown on the right side of the display. You can select an item by touching the screen and can adjust the levels by turning the multi-dial knob.
    Additional Features:
    • Built-in automatic antenna tuner
    • Digital-Up-Conversion (DUC) for clean transmit
    • Dual receivers, dual spectrum scopes
    • DVI-D connector for an external display
    • SD memory card slot for saving data
    • I/Q signal output
    • Memo pad stores up to 10 operating frequencies and modes
    • Quick split function
    • Quick Dualwatch function
    • RF gain and squelch control with a knob
    • RIT and ΔTX variable up to 9.999 kHz
    • UTC/local clock and timer function
    • 1 Hz pitch tuning and display
    • Dial lock function
    • Adjustable main dial brake
    • External speaker jacks for Main and Sub receivers
    • Screen saver function
    • Multi-function meter (S-meter, Power, ALC, COMP, SWR, ID, VD and TEMP)
    • Auto tuning step function
    WB6MMJ, HH2MJF, VA3JHO and 18 others like this.
    No need to wait, just ship it over here.
    Thank you.:):p
    NS8S, N1RCX and KB2QQM like this.
  3. N5UUA
    N5UUA XML Subscriber QRZ Page
    Would love to win this just to make my friend James AA5PD green with envy. He has a 7600 which is very sweet and I use some older Icom equipment such as the 756, 746 and 706MKIIG mobile.
    NS8S and KB2QQM like this.
  4. W4KVW
    W4KVW Ham Member QRZ Page
    If he is like me he would rather have the 7600 since it does not require touching the screen so the radio will operate.I hope I Win it so I can buy another ICOM but it will be a 7800 or another 7600 with the funds from the Resale. :po_O:)
    Clayton
    W4KVW
    NS8S and N5UUA like this.
  5. VP2EQH
    VP2EQH Premium Subscriber QRZ Page
    Had a dream that I was the lucky winner!
    VE1MU, AG7JQ and N5UUA like this.
  6. YD0RXA
    YD0RXA Ham Member QRZ Page
    luv this one
    VE1MU likes this.
  7. KN4MEL
    KN4MEL Ham Member QRZ Page
    I can dream, can't I? Wow!!!
  8. K5RHA
    K5RHA Premium Subscriber QRZ Page
    Sign me up. There's always room for one more rig in the shack!
    VE1MU likes this.
  9. NT4G
    NT4G XML Subscriber QRZ Page
    Mine! Mine!
    VE1MU likes this.
  10. K4MRO
    K4MRO Premium Subscriber QRZ Page
    I would love to have this as my HF rig. working on my General now.
    VE1MU likes this.
