Icom IC 706mk2 filter question
Discussion in 'General Technical Questions and Answers' started by VE3XFD, Nov 2, 2019.
  1. VE3XFD
    VE3XFD XML Subscriber QRZ Page
    First I am new to doing things on my radio. I wanted to add a second filter to my 706 have the the stabdard FL-272 and I added the FL 223 a while back, I got a FL-103 reciently and put it in and the radio would not work at all, pulled the filter out to find that it had no plastic shield on it . when out the radio worked as it has before putting the filter in.
    My question is is the plastic ground shield not on the filter or could it be a bad filter it is an older filter?
  2. W5DXP
    W5DXP Ham Member QRZ Page
    In INITIAL SET MODE, No. 19 & 20, you have to tell the 706 what filters have been installed. Did you do that?
  3. VE3XFD
    YES I did same as when I installed the FL-223 and it worked.
  4. N8FVJ
    N8FVJ Ham Member QRZ Page
    Bad filter?
  5. KG2DX
    KG2DX Ham Member QRZ Page
    Make sure you not put filter in wrong place
