ad: AbAuRe-1
SOLD Icom IC-706 (all versions) Constant Cooling Fan
Discussion in 'Ham Radio Gear For Sale' started by KM4GGH, Feb 12, 2019.
  1. KM4GGH
    KM4GGH Ham Member QRZ Page
    Icom IC-706 (all versions) Constant Cooling Fan-
    Offered here is a device to provide quiet constant cooling air for the Icom IC-706 (all versions) and the IC-7200 transceivers. It is a small 24-volt fan that turns on and off with the radio. It gets electrically connected to the Tuner Control Socket on the back of the radio and draws air out of the cabinet. The fan is mounted to two plastic anchors wedged in the cooling fins.
    There are no modifications to the radio. No holes to drill. No wires to solder. You don't even remove any covers. The power is supplied at the Tuner connector. The fan includes an extension cable to keep the Tuner connector available. You can run both the fan and an external tuner.
    The fan is a 12-volt fan that measures 1.5-in. square. The fan is about 3/4-in. thick. At 12.6 volts dc, It moves 6.0 cubic feet of air per minute. When used, warm air is drawn from the cabinet and cooler air enters the cabinet through the other slots in the cabinet. The fan draws minimal current (90 ma) at 12 volts and runs at all times that the transceiver is turned on. The radio's internal fan is thermostatically controlled and comes on and off depending on operation. At most times during receive the internal fan is not running.
    The fan offered here will function the same on all variants of the IC-706 and 7200. These radios are very busy inside and added cooling can only be a good thing. This fan is added to the transceiver without even removing any covers.
    This is an accessory for the 706. It does not modify the radio. No effect on the warranty. Easy to install, easy to remove.
    No mounting hardware included.
    Price is $25.00 shipped
    Paid via paypal.
    Thanks for looking
  2. KB2FMH
    KB2FMH Platinum Subscriber Platinum Subscriber QRZ Page
    Check your messages Jeff.
    Thanks,
    James - KB2FMH
  3. VK7TZ
    VK7TZ XML Subscriber QRZ Page
    Are these still available please ....Dick cheers.
  4. K8JA
    K8JA Ham Member QRZ Page
    E-Mail Sent To You Jeff ..
    K8JA
  5. KM4GGH
    Sold to James
  6. QRZ
    Important Rules
    Have you read our Swapmeet Rules?
    This forum enforces a set of buying/selling rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Our moderators review every post in this forum and will flag or delete those that do not conform.
