Icom 7300 Connects With LDG AT-600ProII Autotuner For Perfect Match
Discussion in 'Amateur Radio News' started by K0PIR, Feb 20, 2017.
  1. K0PIR
    K0PIR Ham Member QRZ Page
    Maybe not perfect, but if you're running a small amplifier with your Icom 7300, the LDG AT-600ProII Autotuner and M-600 analog meter are a good combination.
    Full article
    F4VSE and W7LDG like this.
  2. K9UR
    K9UR Premium Subscriber QRZ Page
    nice article.
    I run an ALS-600/AT600PROII/IC7300 in one position, and an AL-80/MFJ986/IC7300 in the other position. The automation of the first station is very nice/fast. The metering in the second station is convenient too.
    The ALS600 has a true meter built in, but I like the idea and had not thought about the LDG meter -seems like it would be easy to use your own meter with an interface to the LDG tuner (if it's like the Yaesu meter that LDG makes)- is the meter / tuner combo a true peak reading meter (I use a Kenwood peak reading meter, but i like your point of avoiding one more coax jumper if the LDG tuner/meter combo works as a true peak reading meter.
    K0PIR likes this.
  3. W5DPH
    W5DPH Premium Subscriber QRZ Page
    Very nice write up. I have a AT600proII for sale if any one is interested. W5DPH@YAHOO.COM or 5806951118.
    K0PIR likes this.
  4. K0PIR
    Nice setup Joe and thank you. After having it for a little while and running a few nets with this setup, it's working good and the meter is nice too. The M-600 meter info says that it is a "Peak Hold".
    I also like that I can have the AT-600ProII set for average and the M-600 set for peak. They are independent of each other.
    Thanks again, best 73 - Rich, K0PIR
  5. K0PIR
    Thank you Joseph!
