Ive racked my brain all night searching the internet, hopefully someone here can help! I have the following setup: Dell running Win7 Icom USB driver installed Fldigi installed with Rig cat IC-7300.xml N3FJP Amateur Log installed IC-7300 The Logging software is able to pull information from the 7300, so I know the windows driver works. I am able to see sound data coming/going in the sound control panel within the pc BUT- I am not able to make the 7300 transmit from Fldigi! After reading different instructions and watching a few videos, everything appears good. Am I missing something? Can the 7300 only be associated with one program at a time? Any help is greatly appreciated! Brad W7LZN
Make sure Fldigi is using the correct COM port. Press the Windows and "R" keys simultaneously, type "devmgmt.msc" into the "Run" box, click "OK" and expand "Ports" to see the COM port number. Be sure to click "Initialize" if you make any changes in Fldigi's rig control. Ben
