Icom 706 mk2g problems
Discussion in 'Ham Radio Discussions' started by 9W2KNZ, Dec 15, 2017.
  1. 9W2KNZ
    9W2KNZ Ham Member QRZ Page
    I had a problem with my 706 mk2g. When a few secon i switched on i heard a clicking sound and my radio become deaf and no power output. Now my radio when switched on the signal full on rx but no audio and cant tx. In a few second i'll can heard some signal and power output also ok. Do help me. Thanks in advance
  2. AG1W
    AG1W Ham Member QRZ Page
    Does it have an automatic tuner? It may have frozen up
  3. W4NNF
    W4NNF XML Subscriber QRZ Page
    Could be a tuner problem, yeah. Could be the T/R relay. Could be coax/connections. Could be a lot of things. Step one is to disconnect the rig from an external tuner and/or amplifier or anything else you're using external to the transceiver. Check the coax/connections. Try injecting a signal with a signal generator if you have one.
  4. 9W2KNZ
    ="AC1CX, post: 4489712, member: 846043"]Does it have an automatic tuner? It may have frozen up[/QUOTE]
    No. I'm not using any tuner because all my antennas matches with several freq
  5. 9W2KNZ
    I already disconnect all antennas while i'll switched on my radio a few second it be the same problem
  6. KC8VWM
    KC8VWM Ham Member QRZ Page
    You can try a factory reset.
    Hold [UP] & [DOWN] buttons while turning the radio on.
  7. US7IGN
    US7IGN Ham Member QRZ Page
    I had same issue http://www.us7ign.com/?p=457 and I solved it.
    You can check this point.
  8. KA0HCP
    My MkIIg has about 250,000 road miles on it. Reception became intermittent an poor, signals had a ringing sound. Took radio apart, cleaned and reseated all connectors, ribbon cables, and wiggled all PCB's in mounts. Solved problem.
    AG1W likes this.
  9. KY5U
    KY5U Subscriber QRZ Page
    Possible steps: (Try step, if works stop. If not, do next step.)
    1, Verify power supply voltage (under load) even on a battery.
    2. Do the reset as suggested by KC8VWM
    3. Do the "clean connectors" suggested by KB4QAA
    4. It needs a visit to a repair shop or the more involved (but not the same problem) by US7IGN.
    KA0HCP likes this.
  10. 9W2KNZ
    Ya i know that is not that same problems with US7IGN my radio still can on but right now the signal become full and no audio
ad: KF7PMW-1
