IC7300, Mac, WSJTX How to connect
Discussion in 'Mac Ham Radio on macOS & iOS' started by AC1DV, Aug 6, 2018.
  1. AC1DV
    AC1DV Ham Member QRZ Page
    I downloaded the driver for the IC7300 on my mac and loaded it. When I connect the radio I don't see anything. When I turn on WSJTX and set it for IC7300 It doesn't see the rig. Any suggestions. I WAS using Signalink before with an old 735. So the setting will change I'm sure.
  2. K7GQ
    K7GQ Subscriber QRZ Page
    How do you know that the driver loaded? What Mac OS version?
  3. AC1DV
    Yea, I don't that the driver loaded. Can't figure out how to see if it did. Also I am running High Sierra.
  4. K3DCW
    Check out these instructions from W0MPM. Although written for connecting a 590, the driver installation steps are exactly the same for the Icom 7300 as they use the same chipset.
  5. AD4WX
    AD4WX XML Subscriber QRZ Page
    K0PIR has instructions and videos here for connecting the Icom 7300 to the Mac and using WSJT-X.
  6. W4HRL
    W4HRL XML Subscriber QRZ Page
    To check that the Silicon Labs driver is in fact installed, take a look in MacintoshHD / Library / Extensions for a file named SiLabsUSBDriver.kext.
  7. AC1DV
    That worked.. Exactly what I needed. Thanks MUCH..
