IC 7300 Frequency stability using a GPS reference - anyone done this?
Discussion in 'General Technical Questions and Answers' started by KN4LGM, Sep 14, 2020.
  1. KN4LGM
    KN4LGM Ham Member QRZ Page
    I would like to add a GPS reference to my 7300. Has anyone done this something similar?
  2. W7UUU
    I have an IC-7300... I've yet to feel it's not stable. Not even remotely.
    What issues are you having exactly? Seems "rock solid" on my 7300
    If yours isn't stable, I'd be looking at things like power supply issues....
    Dave
    W7UUU
    W4NNF, W4KJG and KG5THG like this.
  3. KN4LGM
    I am interested in the ARRL FMTs, no I have not noticed any wobble but I would like to add it purely for the FMTs. Also, the 9300(and/or 9700) has a 10 Mhz input so I thought it might be possible on the 7300.
  4. W7UUU
    OH! Well that is most assuredly a higher standard! I get it now.
    The FMT's are no slouch - I used to think they were sort of "relegated to history" but I know it's still very much a big thing.
    Good luck in your quest - I'd be curious how the GPS would be injected etc. - assuming USB / virtual serial port?
    I'll be watching... cool stuff.
    Dave
    W7UUU
  5. W1VT
    W1VT Ham Member QRZ Page
  6. KN4LGM
  7. W9WQA
    W9WQA Ham Member QRZ Page
    not grasping this...?
    following.
  8. G0GSR
    G0GSR Ham Member QRZ Page
    I haven't heard of anyone doing this, probably because its not necessary or worth the effort.
    I check my 7300 against my GPSDO every now and then.
    Last time, it was +7Hz at 70MHz so an insignificant error as the frequency is lowered.
    Frank
  9. PY2RAF
    PY2RAF XML Subscriber QRZ Page
    Doable? Possibly. Worth it? I doubt.
    IC-7300 sports a Murata XTCHH oscillator for the FPGA, with +-1 PPM stability. After a initial calibration / frequency alignment in lab, the equipment should be rock stable in HF bands. As @G0GSR mentioned above, that would translate to +- 7 Hz deviation in the worst-case, highest band - 70 MHz band. If you're a 20 meter use? That translates to +- 1.4 Hz deviation.
    Feasibility:
    The tuning (blue arrow) is performed inside the FPGA:
    The FPGA is fed by a 41.344 MHz clock rate: (click to enlarge)
    So, you would have to essentially have your GPSDO output this clock rate, yank off the existing clock, properly buffer and then feed it to the FPGA.
    Remember, if you lose sync/clock, it will probably cause a number of other problems of the radio, as the FPGA controls a number of functions on the radio.
    Again; worth it? I doubt it.
    - RF.
  10. KN4LGM
    The person who won the last FTM was only of by a 100th of a hz off, that is why I want to do it. However, I see what difficulties would come with replacing the existing clock, thanks.
    PY2RAF likes this.
