IC-575A
Discussion in 'VHF/UHF - 50Mhz and Beyond' started by W4WVW, Jan 14, 2020 at 4:11 PM.
  1. W4WVW
    W4WVW Ham Member QRZ Page
    My ICOM 575A stopped working on upper sideband. No xmit output and the recever is dead quiet even with the squelch turned completely down. This is on both 6m and 10m. All other modes are working fine. Any ideas or do I need to brush up on my CW, hi hi?
    Section 2 of the service manual provides lots of things to check -- have you tried following that yet?
  3. W4WVW
    I didn't have a service manual, just the instruction manual. I located the service manual online and now I have it. The procedures in section 2 may go beyond my test equipment inventory and technical expertise. I did notice that the procedures didn't seem to make any distinction between modes of operation. I think I'll nose around inside the radio a bit and see if anything obvious stands out. It's possible it could just be a faulty SB selector switch. Thanks for your reply.
    Probably not the switch, the LSB/USB indicator does change on the display.
