SOLD IC-37A Icom 220-225 Mhz FM Transceiver
Discussion in 'Ham Radio Gear For Sale' started by NJ6F, Oct 10, 2019.
  1. NJ6F
    NJ6F Ham Member QRZ Page
    IC-37A Icom 220-225 Mhz FM Transceiver Used, with Microphone, Needing Fun Touchup Mod’s.
    Want a nice project to keep you doing what you like as it gets colder. Ah…. the nice smell of solder and a rewarding project.
    · Here is a fun 5/25 watt 220 FM radio that is very compact with spec sheets and mods below in JPG’s
    · Radio works after it is on for a little while, sometimes right away, or in 10 minutes, and pigtail is moved. Once working it stays consistent.
    · Problems are the following:
    · Audio and squelch control are fixed resistors replacing bad wiper’s long ago with plenty of documentation on web on fix’s. Plenty of volume, and squelch is adequately peaked for no noise, not too tight, just right. So that proved adequate for myself.
    · Other item it needs to have the pigtail replaced with a RF chassis connector and the pigtail causes the PL to get corrupted in high power so simple replacement will get you a better working rig and a fun project. Standard known documented stuff, see below.
    · In its present condition I have spent a few years using it on one of the local repeaters. Yes it has I believe 10 memories that all work.
    · Display has some partial elements out but you can tell where you are number wise.
    · It is one of the smallest base radios put out in the 80’s and a lot smaller than the IC-38.
    Unit for sale is in working to partial working order and prefer to use PayPal and if not used to it I will walk you through it. Sold as is, all sales final from a non-smoking home. Had another rig I am using presently. You will grow fond of her.
    USPS, standard shipping, $44 with $10 for shipping in continental 48 states. $54 total. Contact me direct as well at NJ6F@cox.net or text at 619-444-8300 Santee, CA 92071
    73 - Rich – NJ6F
  2. NJ6F
    Sold
  3. QRZ
    Important Rules
    Have you read the Swapmeet Rules?
    This forum enforces a set of buying/selling rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Got questons? Contact our moderation team here...
    All Sellers Must Be Verified As of July 1, 2019, only Verified Users are permitted to post in this forum.
