I need a bit of assistance on a switchbox
Discussion in 'Homebrew and Kit Projects' started by KI5OMM, Oct 10, 2021.
  1. KI5OMM
    KI5OMM Platinum Subscriber Platinum Subscriber QRZ Page
    I want to try a simple homebrew project of building a microphone switch box so that I can run a single boom mic into two different radios. It's all simple straight thru wiring and 4-pin XLR chassis mount connectors.
    I need a rotary switch that will take a 4 conductor input and switch it to either A or B output. My question is what is the correct terminology of the switch? Would it be a 4 conductor 2 position rotary switch? Also where would be a good place to purchase it? Mouser?
    Next, should I be concerned about RF if I use a plastic box or should I use an aluminum box?
    Any ideas or tips would be much appreciated!
  2. WB8NQW
    WB8NQW Ham Member QRZ Page
    4 pole double throw toggle switch should work fine. No need for a rotary switch.
    KU3X likes this.
  3. KI5OMM
    I believe you are right. That will work just fine for this application. This is my first homebrew from scratch, so I am learning as I go. Thanks for the tip!
  4. N2UHC
    N2UHC Ham Member QRZ Page
    I used one of those old computer A/B switch boxes to switch between a microphone and a computer interface for digital modes with the output going to my radio. I believe the rotary switch was a 25 pole, double throw switch, so plenty of connections for microphones.
    W4XXV likes this.
