I 746 Pro RF Power Output QRP CW.
Discussion in 'Ham Radio Discussions' started by WI4MM, Nov 25, 2021.
  1. WI4MM
    WI4MM Ham Member QRZ Page
    I use a 746 pro in CW QRP. As per the manufacturer, it's less than 5 watts RF output.... on radio shows no output rf, however, it is transmitting due to amp load increase on Astron power supply.
    Anyone know the actual rf output at the lowest in CW, my outboard meters are not that accurate .
    Thanks ,de WI4MM ..
  2. KC3RN
    KC3RN Ham Member QRZ Page
    As per the manual, minimum output power is 2 watts.
  3. WI4MM
    My manual reads "5 watts or considerably less". Thanks for your reply.
  4. W4JFA
    W4JFA Ham Member QRZ Page
    Maybe get the output power meter calibrated. But still it'll be reading around 2 - 5 watts on a 100 watt scale. Accuracy????
  5. K0UO
    Most of the ones I've seen on the Icom radios are all about the same/ between 1 to 3 watts, now that's QRP/ you don't see any output on the actual meter but you're still putting up at least a Watt or 2
ad: Morse-1
