HRD Rig Control for FTDX3000
Discussion in 'Amateur Radio Software' started by KB7AK, Oct 6, 2017.
ad: DLSpec-1
  1. KB7AK
    KB7AK XML Subscriber QRZ Page
    I have set up HRD to remotely control my FTDX3000 and I am also running WSJT-X. The "remote" is quite a word, because it really is only a few yards, but I am so space limited right that this is the best solution. I can't figure out how to change the RF output power through HRD, can someone give me a hint?
  2. W6IR
    W6IR Ham Member QRZ Page
    You need to customize the layout and add a slider for RF Power. Lots of other options as well.
    KB7AK likes this.
  3. KA9JLM
    HRD can put your radio into transmit when you do not expect it.
    A computer reboot may make it transmit until the adapter drivers are loaded too.
    Have Fun.
    KB7AK likes this.
  4. KB7AK
    experienced it myself, especially when DM780 is loaded automatically, freaked me out the first time....
  5. KA9JLM
    I have known a few people that smoked their radio or power supply because of that.
    A PTT disable is a good thing to have. Harder to do if running remote.
    Some radios have a built in time out timer. That is a good thing.
    The FTDX3000 may have a TOT setting.
  6. KB7AK
    W6IR, following your advice, I can still not find how to control RF output, I found every other dial :)
  7. W6IR
    Not in my experience with the FTDX-3000 or the FT-991.
  8. KB7AK
  9. KB0LTY
    KB0LTY Premium Subscriber QRZ Page
    Not sure if you ever found it, but thought I'd post in case you haven't or someone else is looking. I found it under customize sliders, it's called "MAX RF Power"
  10. K5TSK
    K5TSK Platinum Subscriber Platinum Subscriber QRZ Page
    Cruising by and read this about the FTdx3000. I don't have HRD installed on my machine and FTdx3000, but did experience that power up on reboot a few minutes ago. Hit the power switch, finished booting and then turned on the rig. No problem after reboot. Highly coincidental I read this post right after it happened. New user to Ubuntu 16.04 LTS. Using SKCCLoggerx64, flrig, CQRLOg. First time this has happened in 18 months of using linux. Also first time using Ubuntu and SKCCLogger. Scary. Maybe we need a new thread for this problem. Jim K5TSK
