ad: TinyPaddle-1
How to Winterize Ham Radio Gear with DX Engineering
Discussion in 'Amateur Radio News' started by KN6NWZ, Oct 14, 2021.
  1. KN6NWZ
    KN6NWZ Ham Member QRZ Page
    Tim Duffy K3LR shares winter preparedness tips as it relates to ham shacks and outdoor gear as well as a contesting rig recommendation. Don AE5DW presents Amateur Radio Newsline with Dr. Tamitha Skov, Space Weather Woman. Amanda K1DDN has recommendations on how to plan ARES events.
    KC7ZXY, K0UO and M1WML like this.
  2. KN6NWZ
    If you have any recommendations for show topics, please drop them here!
    WD4ELG likes this.
  3. M6EVR
    M6EVR Platinum Subscriber Platinum Subscriber QRZ Page
    thanks for a great show, learnt a lot from it too 10/10
    KN6NWZ and M1WML like this.
  4. M1WML
    M1WML Ham Member QRZ Page
    KN6NWZ likes this.
  5. K6CTW
    K6CTW XML Subscriber QRZ Page
    An interesting topic would be Rob Sherwood's latest on current transceiver performance and comparison. Similarly fa comparison a few of the current amplifiers both Full QSK and non-QSK, solid state (instant-on) and otherwise.
    73 - Ken Miller, K6CTW
    M1WML likes this.
  6. KN6NWZ
    Thank you so much! The hosts have so much collective knowledge!
    M1WML likes this.
  7. KN6NWZ
    Thanks for the suggestion!
    M1WML likes this.
  8. KA9JLM
    How to make batteries last in cold weather... ?
    KC7ZXY and M1WML like this.
  9. KA4KOE
    KA4KOE XML Subscriber QRZ Page
    Do a show on the HF Pack portable folks; Bonnie Crystal is a good person to check with.
    M1WML likes this.
  10. M7BLC
    M7BLC Ham Member QRZ Page
    My gear will survive the cold in my garage but I am not sure I will !
    NE2E and M1WML like this.
  11. AJ4AC
    AJ4AC XML Subscriber QRZ Page
    When are the older guys coming back to host the show?
    M1WML and KE0GXN like this.
  12. K8XG
    K8XG Ham Member QRZ Page
    Keep them charged up and warm
    M1WML likes this.
  13. KF0DHQ
    KF0DHQ Ham Member QRZ Page
    Make a show about solar panels, solar charge controllers, and batteries!
  14. K8XG
    Home setup:
    Solar panels, Renogy 100 watt panels in a 4 set or 8 set, or 12 set.
    Controllers , Renogy Rover MPPT get 12-72 input from cells and 12/24 to battery
    https://www.amazon.com/Renogy-Charge-Controller-Compatible-batteries/dp/B01MSYGZGI/
    Batteries : Deep cycle AGM is best cost ratio
    Portable:
    Solar Panels, PowerWerx 165 Watt foldable that are using the new tech that has no lines on the cells, if you can afford it Global Solar or Power Film $$$ {I have two 'blems' in desert camo I picked up at Xenia for a huge discount fold up into about 9x11 and fit in my back pack}
    Controller, Their charger PowerWerx sell as an accessory, or West Mountain Epic Powergate; no RFI at all [Steely Dan FM cite]
    Batteries: Bioenno LiFePO4 except no substitutes
    Edit: the $20 Amazon controllers are full of RFI and stay away from them. Many counterfeits are burning batteries up as well...Min low cost controller I have tested is the $49 Bioenno controller for a small setup. Mine has a "little" RFI at times. Others have said their's has none.
    KC7ZXY, KF0DHQ, NL7W and 3 others like this.
  15. KD8ZM
    KD8ZM Ham Member QRZ Page
    Be sure to put antifreeze in your radios before the first frost.
    KB1MM, N7ITA and N3FAA like this.
ad: BridgeCom-2
